Collection of differences between original master version and realthunder
Report observations made with the new Toponaming branch.
thomas-neemann
Re: Collection of differences between original master version and realthunder
Post by thomas-neemann »
bambuko wrote: Thu Apr 21, 2022 7:25 am doesn't always work that well, but on a whole Linkstage3 branch copes better with such TNP issues!
BTW now that we have dedicated forum section, this thread should be moved there:
That's how I see it too, thanks
Done.
thomas-neemann
thomas-neemann wrote: Thu Oct 28, 2021 6:49 pm this bar can be switched off in realthunder.
in the master you can still not switch it off (via the tick)
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28751 (Git) AppImage
Branch: (HEAD detached at 660655e)
Hash: 660655e54c97b5017ff0ac1e030059308cd4e3f5
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
thomas-neemann
apparently contraints in assembly3 in master are not working properly
https://www.youtube.com/watch?v=Se-tMzkKaj4
phpBB [video]
realthunder
Version: 2022.430.26244 +4758 (Git) AppImage
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
master
Version: 0.20.28765 (Git) AppImage
Branch: (HEAD detached at 795f86c)
Hash: 795f86c18c22260cfc3627bdd5b71504b9dca4ef
edit
the difference is that auto recompute is pre-set in realthunder. not in the master
Last edited by thomas-neemann on Mon May 02, 2022 12:49 pm, edited 1 time in total.
bambuko
Post by bambuko »
thomas-neemann wrote: Mon May 02, 2022 8:14 am ...https://www.youtube.com/watch?v=Se-tMzkKaj4...
I refuse to look at Youtube without at least some indication in writing, here in the forum, as to what am I supposed to expect to see there.... :twisted:
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
thomas-neemann
bambuko wrote: Mon May 02, 2022 9:43 am
the connection is not fixed in the master, in realthunder you cannot disconnect it with transform
bambuko
Post by bambuko »
thomas-neemann wrote: Mon May 02, 2022 9:59 am the connection is not fixed in the master, in realthunder you cannot disconnect it with transform
Are you using standard transform (https://wiki.freecadweb.org/Std_TransformManip) ??
BTW there is (and I was there some time ago as well :lol: ) a lot of confusion about using standard transform after constraining assemblies.
from @realthunder:
It is not possible to use the Transform command for moving assemblies, because assembly mover is aware of assembly hierarchies and will modify the the Placement property of the correct assembly/part object in the hierarchy, while the Transform command only works for the selected object.
see: https://github.com/realthunder/FreeCAD_ ... -835246489
Have you got "auto recompute" set on in both Link and Master? - doesn't look like it to me?
This video doesn't prove a lot.... and most certainly not that:
"...assembly3 in master are not working properly..."
It looks to me more like user error ;)
thomas-neemann
bambuko wrote: Mon May 02, 2022 12:20 pm ...
Have you got "auto recompute" ...
Thanks for the tip, that's the solution. the difference is that auto recompute is pre-set in realthunder. not in the master.
thomas-neemann
this hotkey has probably changed.
source: https://wiki.freecadweb.org/Sandbox:Key ... _Workbench
in realthunder it is as described in the documentation. in the master it is still the old method
Version: 0.20.28774 (Git) AppImage
Branch: (HEAD detached at 716213b)
Hash: 716213beacd25a907f2c164ad8ef8309b8a284b0
Branch: LinkDaily
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
thomas-neemann
master has .57 point cloud import. realthunder doesn't have it
edit .e57
Last edited by thomas-neemann on Fri May 06, 2022 12:53 pm, edited 1 time in total.
