An exploration into the Icon theme
- MisterMaker
Re: An exploration into the Icon theme
It is symbolic but it's a bit of a hassle to put so much into so little pixels.
That theme idea of big red arrows and such, is a great idea but it should be a theme on itself. My goal is to be more industry standard. Which is a bit boring but we want to get people to use Freecad and this is in my opinion a good way for luring those users to Freecad.
There is some logic in the copy geometric icons.
Like the sync are 2 green lines moving towards each other to sync.
The fix are 2 broken reference lines that make a cross.
Freeze has the color of reference geometry, since that is what it is after you freeze it, just a reference line.
Now I am reading all comments I just prefer pumping out icons instead of focusing on the difficult icons, often idea's pop-up after you took a bit of distance from it.
So in that expect, I spend some time on the constrains and dimensions.
And yeah, dimensions are just constrains with distances. BUT YOU CAN'T TELL ME WHAT TO DO!
So they get a different color, probably lots of long time CAD users agree with me on this, since dimensions and constrains are almost always separated from each other. Although having 3 extra colors for constrains is bit of a nightmare, I really need to get that color pallet plugin!
For the TLDR here some pictures: Before and after, be aware that image compression ruins it a bit. The icons in the sketcher are super sharp.
- adrianinsaval
- MisterMaker
Does anyone have any thoughts about these icons:
Solidworks:
Inventor:
creo
You bet I am going to axe the KDE icons
Solidworks:
Inventor:
creo
Yes, my pet PITA is "Open" icon which looks confusingly similar to "Group" icon.
Would love to make them more distinct?
- MisterMaker
Browsing true other CAD programs it seems like some kind of derivative from the windows default icons is the way to go.
It's also logical to-do since we already have the Linux icons, and so giving user the choose between the 2 would be nice.
If you are a mac user, make your own
That is what I was talking about
It would be desirable to avoid similarities like this
- MisterMaker
I don't have that icon, I guess it is the open directory in my release it doesn't has an icon as you can see below.
This is my first go at the icons.
I was really struggling with the disk color. Black isn't good visible with the dark theme, and gray looks similar to the grayed out symbol. So I ended up with blue. I am not sure if dark blue has enough contrast with the dark theme
It looks better on the white theme. But I realized icons for white theme are in general easier as you have better contrast.
- MisterMaker
Ok some after some nice people bought my icons I bought the Blender addon and now I can easily make new theme's. As to test the addon I recreated the default theme. I think the saturation is still a bit too low. Bot I keep going to high and too low, it's a bit difficult to get it precisely right.
So cool, but can you help me to understand how buying the blender addon helps you make freecad themes?
- MisterMaker
It's a color managing addon, without it I had to manually change ever material color. I had too go true every shader change the color, and save the last color somewhere in the case I wanted too re-use it.
Now I can make a color pallet give it a name and just switch too it. Basically a 30 minute job of switching themes changed to 1 second.
Blend file will still work without it but you are back to manual color switching.
