Additive Pipe fails on path, Link Path Array Works?
Report observations made with the new Toponaming branch.
Outsourced
Post by Outsourced »
OS: Windows 10 Version 2009
Version: 2022.407.28576 (Git)
Branch: LinkStage3
Hash: 599f7663af69d3dbd77063e834b12f26da513b2d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Hello FC
Please find the file included, https://drive.google.com/file/d/1y89ueB ... sp=sharing
If OCC is able to project a compound 200+ times along a path using link array, It should be able to sweep along that same path using additive pipe -shouldn't it?
I then tried to sweep (A.P) along the individual line segments but I was also greeted with multiple crashes & fails.
I was hoping to experiment with a Rope texture on the surface, mmmm never got that far.
Correction, I did on a previous document but the graphics are messed to which I tried to resolve using Angle deflection & Deviation. But with no success, I;m am just guessing the numbers TBH.
Anyways this is the file with slightly different tree.https://drive.google.com/file/d/1y89ueB ... sp=sharing.
Kind Regards
Clark Kuant
Design Community
https://www.youtube.com/channel/UCTFFPB ... KJBZEhSXBA
Re: Additive Pipe fails on path, Link Path Array Works?
Outsourced wrote: Fri May 20, 2022 2:44 am If OCC is able to project a compound 200+ times along a path using link array, It should be able to sweep along that same path using additive pipe -shouldn't it?
No, not at all. There is a formal reason: Sweeps must not contain self intersections. And there are OCC limitations: such as sweeps failing on nearly-but-not-quite 180° connections of lines.
