The issue is mostly about the questionable choice of white color for the snap point. In your OP, you are trying to show the snapping point of the moving object, which is a rare case I'd say. I expect in most cases, the user would want to snap to other objects, hence without selection highlight, make it easy to see the snap point. And I've tested that it works about the same as the upstream master. It works better if you enable both selection on top and preselection on top.
With the LinkDaily branch (the one you just installed), you can also try the experimental render cache, which works better in all cases.
(SOLVED) Snaping point is not displayed
Re: Snaping point is not displayed
FYI that color can be changed in the preferences. See Draft_Snap#Preferences.realthunder wrote: ↑Sun Jun 26, 2022 12:47 am the questionable choice of white color for the snap point.
I must be doing something wrong again ....
I worked out the snap colour change (same as? @Roy_043 ): Selection settings were (same as? @realthunder ): and yet... when I try to select, snapping point (@thomas-neemann) is not displayed?? Any ideas, please, what am I doing wrong?
OS: Ubuntu Core 20 (Pantheon/pantheon)
Version: 2022.625.14555 (Git shallow)
Branch: (HEAD detached at 2022.06.25-edge)
Hash: 0191f4edf1b19bf52124a4be654074b5cc035645
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
Can you please send me your user settings? Tools -> Edit parameters -> Export.
Thank you - I have sent you a PM
possibly a clue?
when using:
and
when using:
10:36:58 Running the Python command 'Draft_Snap_Center' failed:
File "/tmp/.mount_FreeCAunleRl/usr/Mod/Draft/draftguitools/gui_snaps.py", line 385, in Activated
sync_snap_statusbar_button("Draft_Snap_Center_Statusbutton", status)
File "/tmp/.mount_FreeCAunleRl/usr/Mod/Draft/draftguitools/gui_snaps.py", line 89, in sync_snap_statusbar_button
for a in ssb.menu().actions() + ssw.children()[-6:]:
local variable 'ssb' referenced before assignmentPick end point
OS: elementary OS 6.1 Jólnir (Pantheon/pantheon)
Version: 2022.430.26244 +4758 (Git) AppImage
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
10:39:39 Running the Python command 'Draft_Snap_Center' failed:
File "/snap/freecad-realthunder/47/usr/Mod/Draft/draftguitools/gui_snaps.py", line 385, in Activated
File "/snap/freecad-realthunder/47/usr/Mod/Draft/draftguitools/gui_snaps.py", line 89, in sync_snap_statusbar_button
local variable 'ssb' referenced before assignmentRunning the Python command 'Draft_Snap_Center' failed:
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
- thomas-neemann
it works now, thank you very much
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2022.704.28821 (Git) AppImage
Branch: LinkStage3
Hash: c83a0368027dcdb972bfb3e0a00fbf9c26536fcd
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
