Starting having issue with new documents not resizing Origin planes to object/sketches. It ends up having the origin plane within the object, so I have to hide the object to select them.
They work correctly in older files I have created, so it leads me to think I hit some hot key or something that changed how they function now in new documents.
Example of problem when starting a new Sketch in Body in Part Design:
If there isn't an option to change this in FreeCAD, maybe it's just a bug I have ran into with the LinkStage3 build?
Edit:
Adding Versioning info and attaching a file which has the issue.
OS: Windows 10 Version 2009
Version: 2022.709.26244 +5001 (Git)
Branch: LinkDaily
Hash: 096210d21183e9dfdc3b25777760bfb6c00a210b
Python version: 3.8.10
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.6.2
Issue only started happening late last week, so I am assuming it must be some setting I changed somehow, somewhere.
Origin Planes not Resizing to object
- Basic Standard Empty Spool.FCStd
- (113.39 KiB) Downloaded 35 times
Re: Origin Planes not Resizing to object
Please provide file and full information as described in the link of the big red banner.
Without it it's just guessing.
- Shalmeneser
OK, everything works well on the vanilla version of FreeCAD. I move this to LinkDaily.
- Shalmeneser
vanilla version :
- Basic Standard Empty Spool_SHALM.FCStd
- (94.95 KiB) Downloaded 35 times
- Capture du 2022-09-19 18-01-09.png (30.88 KiB) Viewed 913 times
