new tree view behavior is less productive
kisolre
Re: new tree view behavior is less productive
Postby kisolre » Wed Oct 09, 2019 5:05 pm
vocx wrote:
Wed Oct 09, 2019 4:49 pm
I think this is the Label2 attribute.
Shouldn't this be exposed in Data tab?
vocx
Postby vocx » Wed Oct 09, 2019 5:18 pm
Maybe, yeah. I'm not sure if this is implemented for all DocumentObjects, or just App::FeaturePython, or Part::FeaturePython, that is, those with 2D and 3D shapes.
realthunder
Postby realthunder » Wed Oct 09, 2019 11:21 pm
uwestoehr wrote:
Wed Oct 09, 2019 3:22 pm
There is another tree view issue:
- It is no longer possible to change the width of the Labels & Attributes column in the tree:
But you can't change the width in 0.18, either. Because there is only one column in 0.18 tree. I added another column for general purpose description or whatever. If auto sizing is not enabled, then it is possible to obscure the object names in the tree which will be more disturbing.
You can edit the description directly in the tree, just like object labels.
uwestoehr
Postby uwestoehr » Wed Oct 09, 2019 11:32 pm
Yes, but there is no need for that because when renaming you don't need more space. But now, renaming needs more space for the formula icon that will be displayed behind the name.
Why is it necessary to have the formula editor icon on the name fields?
Anyway, enabling to change the column width is just a Qt UI setting, And I think it should be enabled, independent of the formula editor icon.
realthunder
Postby realthunder » Thu Oct 10, 2019 12:06 am
It allows the user to name the object with expression, but yeah, it should be considered as a power feature. I shall hide it by default.
Yes, it's easy to add.
uwestoehr
Postby uwestoehr » Thu Oct 10, 2019 12:18 am
OK, but document this please. By the way, where do I find info like about this feature?
Thanks.
realthunder
Postby realthunder » Thu Oct 10, 2019 1:44 am
It's an extension to the FC expression engine. Previously it can only bind to numerical property. Now it can bind to all. I have modified the PR thread for a temporary document of all the expression enhancement.
kisolre
Postby kisolre » Thu Oct 10, 2019 6:01 am
How? RMB/Rename edits the label, double click has corresponding action.
Postby chrisb » Thu Oct 10, 2019 6:09 am
On MacOS I can edit the names with return key. And luckily the same works for the description :D ! This new possibility is highly welcome here, as I don't have to describe things in the label, as I do now.
Snip macro screenshot-c173cf.png (20.56 KiB) Viewed 287 times
Tiny imbalance: The description should go at least up to the right end. There is no need to have something beyond.
realthunder
Postby realthunder » Thu Oct 10, 2019 6:37 am
Click the description field of an object, and press F2. I'll modify the rename action for that too.
