[Feature Request] Geometric and mass properties
it would be great to have an option to obtain the following information about the model using built-in tools (without macros and Python codes):
1) in sketcher (section properties):
- area
- centroid coordinates (with respect to sketcher axes)
- second moments of area (with respect to centroidal axes)
maybe more if possible (like polar second moment of area)
2) on part level:
- volume
- surface area
- center of mass
- moments of inertia (with respect to center of mass)
maybe also moments of inertia with respect to selected point
What do you think?
- area
2) on part level:
- volume
- surface area
- center of mass
What do you think?
Re: [Feature Request] Geometric and mass properties
Yeah, I've seen this. It's really nice but maybe something like that could be built into the FreeCAD. Also, this macro won't give me second moments of area for a section.
Macros can simply be added to the toobar.
Macros can be modified to get second moments.
That what flexibly is all about.
I suspect you are correct that it has been done.
mario, who is mentioned in this forum post: https://forum.freecadweb.org/viewtopic.php?t=11290
would probably modify the info macro.
He'll probably pick up on this thread, or you might post in that thread and ask.
Part_CheckGeometry shows a lot (if not all) of these.
hi
my macro (FCInfo) work only with unique object and give "maximum" info of this object
the macro work only outside Sketcher and not inside Sketcher i tray for work inside sketcher but certain dimension hare good and other not then sorry also for my i abandoned this option
for the moment of inertia is other expert user who worked on it see "https://forum.freecadweb.org/viewtopic.php?f=22&t=23888" i am not knowledge for this (my i use only the result give by FreeCAD command) :
if you have concrete formula or other demand and if i can adding it ... no problem
mario
m = FreeCADGui.Selection.getSelection()[0].Shape.MatrixOfInertia
mario
Thanks for replies. When it comes to FCInfo macro, would it be possible to add an option to calculate and display second moments of area (by clicking on a selected face outside of the sketcher) ? Or does it work only for whole parts (volumes) ?
hi
FCInfo work for the volume (complete object)
but maybe Part > Create a copy > Create element copy Part_ElementCopy (for create a independent face)
and test it ?? I do not know
mario
mario
