[Features Requests] Sketcher Radius/Diameter presentation
Re: [Features Requests] Sketcher Radius/Diameter presentation
I am happy with any solution beyond the purely horizontal line.
And I am not unhappy with the solution we have now :) .
bleber
Post by bleber »
Can Make a diàmetre or radius presentation on non circular object? Kike radius on sketch that need to be revòlvef towards Axis.
bleber wrote: Sun Aug 01, 2021 12:37 am Can Make a diàmetre or radius presentation on non circular object?
No.
abdullah
Post by abdullah »
Oh that was an interesting read. I will start review of this now. Sorry OpenBrain for the huge delay. Kudo's for the community interaction ;)
abdullah
Post by abdullah »
I encountered a little buggy for the case of external geometry group constraining:
Which should be:
I have already a fix for that locally (no need to update the PR).
About the parameter name, I have changed them in my local commit to:
        labelPosition = hGrp->GetFloat("RadiusDiameterConstraintDisplayBaseAngle", 15) * (M_PI / 180); // Get radius/diameter constraint display angle
        labelPositionRandomness = hGrp->GetFloat("RadiusDiameterConstraintDisplayAngleRandomness", 0) * (M_PI / 180); // Get randomness
Believe it or not, it took me a while to understand "Disp" (Disponibility?).
Then I have some minor code naming things. Like changing finishDistanceConstraint to finishDatumConstraint as now it does more than distances, giving it an additional parameter to handle the case with multiple constraints (the bug above), and some extra checking to avoid unconditionally setting/assigning the label position to all constraints. While now other constraints ignore this field, this may change and would lead to unexpected behaviour.
For the rest I think that functionality and code is ok.
Hopefully tomorrow I will test my local correction commit and will merge PR and my local commit with minor fixes.
The important bit I wanted to convey is the change of the name of the parameters, as this will go to the wiki.
openBrain
Post by openBrain »
abdullah wrote: Thu Sep 23, 2021 6:07 pm I encountered a little buggy for the case of external geometry group constraining:
Indeed. I remember I didn't think about testing this. :lol:
Yes, as a non native English speaker, less vocabulary is less confusing. :) -- I'll look for this word, that is pretty the same as the French one for 'availability'. Maybe a false friend --.
Then I have some minor code naming things. Like changing finishDistanceConstraint to finishDatumConstraint as now it does more than distances...
Sounds great.
Very good idea, I probably wouldn't have check for an extra commit when documenting. :P
abdullah
Post by abdullah »
There was another thing. This seems to be intended for circles, but not for arcs:
I modified it so that arcs are excluded:
abdullah
Post by abdullah »
git commit 873e0977cae84d96153ba6040fe7601a73ce5f1e
openBrain
Post by openBrain »
I'll document in the coming hours. ;)
M4x
Post by M4x »
Thanks to everybody involved! I've to admit I love free software! :mrgreen:
