how add custom properties to any object?
jtm2020hyo
Postby jtm2020hyo » Thu Jan 28, 2021 10:29 am
Something like AutoCAD blocks and Attribute properties, how can I add custon properties any object and introduce expressions, and if possible introduce scripts?
Re: how add custom properties to any object?
Postby chrisb » Thu Jan 28, 2021 12:05 pm
Don't know AutoCAD blocks.
Additional properties can be added, by right clicking in the Properties section and then "Show All". Then you can edit custom properties.
Expressions are possible, scripts are forbidden due to security risks.
jtm2020hyo
Postby jtm2020hyo » Thu Jan 28, 2021 12:20 pm
nice feature, but when I added my custom property appears nothing.
chrisb wrote: Thu Jan 28, 2021 12:05 pm Expressions are possible, scripts are forbidden due to security risks.
how can I unlock the script inside properties?
hmk
Postby hmk » Tue Feb 02, 2021 12:36 pm
jtm2020hyo wrote: Thu Jan 28, 2021 12:20 pm nice feature, but when I added my custom property appears nothing.
It works for me. I created a group "Params" with names "Height" and "Diameter" for a Body. The group shows up at the very end.
Screenshot from 2021-02-02 13-33-34.png (68.46 KiB) Viewed 715 times
OS: PureOS (GNOME/gnome)
Version: 0.19.23756 (Git) AppImage
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
jtm2020hyo
Postby jtm2020hyo » Tue Feb 02, 2021 2:49 pm
thanks for the answer, I noticed than is possible add properties, but not all properties.
a link to any documentation could be great, but I am more interested in add custom properties and add custom properties with scripts.
for example, in a Circle Draft Object, How can I calculate the perimeter? until I know it needs scripts.
hmk
Postby hmk » Tue Feb 02, 2021 5:57 pm
jtm2020hyo wrote: Tue Feb 02, 2021 2:49 pm for example, in a Circle Draft Object, How can I calculate the perimeter? until I know it needs scripts.
Have a careful look at the screenshot.
You have limited ability to "script" things with expressions. Most importantly, you have the ?:-Operator, which gives you basically If-Then-Else. I have only tried little examples so far. These expression can easily break, I believe.
Note: You have to pick the right return type: For first expression I did use String, for the second Float.
Have a look at this thread: https://forum.freecadweb.org/viewtopic.php?f=27&t=38974
Screenshot from 2021-02-02 18-56-10.png (122.99 KiB) Viewed 644 times
jtm2020hyo
Postby jtm2020hyo » Wed Feb 03, 2021 7:48 am
Look cool
... Just for be clear, then is not possible add a python script to properties right?
jtm2020hyo
Postby jtm2020hyo » Sun Jun 13, 2021 11:55 pm
I find another method:
look like in "Shape" Property has stored all values that we wish.
Postby chrisb » Mon Jun 14, 2021 5:32 am
jtm2020hyo wrote: Wed Feb 03, 2021 7:48 am ... Just for be clear, then is not possible add a python script to properties right?
As mentioned above: arbitrary Python scripts are forbidden due to security risks.
ifohancroft
Postby ifohancroft » Tue Sep 14, 2021 10:03 pm
Can you access custom properties of a parent object?
Like if I have a Sketch, inside of a Body inside of a Part, can I add a custom property to the Part then access that as a dimension constraint in the Sketch? How?
I like to make, break & modify stuff via a soldering iron, code or both. https://ifohancroft.com
