[DISCUSSION] Constraint's Widget - Open topics
abdullah
Re: [DISCUSSION] Constraint's Widget - Open topics
Post by abdullah »
M4x wrote: Sun Oct 24, 2021 8:51 pm I'm not using a custom stylesheet if you've something like that in mind.
Wow! You did a lot of tests.
I found this possible work-around:
https://askubuntu.com/questions/972276/ ... in-gnome-3
and this suggestion that it relates to gnome window manager:
https://forum.qt.io/topic/120852/make-m ... le-again/5
Did the work-around help?
Is it only this specific dialog or you do have other dialogs of FreeCAD showing this behaviour?
If other dialogs do not suffer from this issue, then I might be able to compare dialogs and "find the difference". It may be that I set some property in the dialog that I should not have...
M4x
Post by M4x »
abdullah wrote: Mon Oct 25, 2021 2:11 pm Wow! You did a lot of tests.
That's the least I can do.
abdullah wrote: Mon Oct 25, 2021 2:11 pm I found this possible work-around:
Wow, thank you! Tweaks is already installed and in use. One of the first things after a new install. "Attach Modal Dialogs - When on, modal dialogs are attached to their parent windows, and cannot be moved." was turned on. :roll:
abdullah wrote: Mon Oct 25, 2021 2:11 pm Is it only this specific dialog or you do have other dialogs of FreeCAD showing this behaviour?
The window which opens after taking a screenshot via the Macro_Snip behaves the same. Actually it's pretty useful regarding posting pictures to the forum :mrgreen:
Macro_TechDrawTools opens in a window which doesn't move with the parent window (Attach Modal Dialogs turned on).
abdullah wrote: Mon Oct 25, 2021 2:11 pm Did the work-around help?
When I turn Attach Modal Dialogs off, the main windows stays where it was - yes.
adrianinsaval
Post by adrianinsaval »
