[SOLVED]Solid created by shell-faces-tollerance-sew has problem. Sew or Tollerance dosen't create solid?
My EdgeExtend supposed to create solid .. my code should create a solid but when I try with python to check it if it is solid .. it fails.
I upload the file and the picture of the code I used. And I checked even with defeaturing geometry check ...it should be ok. but it isn't.
bug in Part WB? or what?
what you see in the left is the answer of the defeaturing WB - geometry check. and in the right is the code i used to check but it says "Shell"
thanks in advance.
thanks in advance.
- test.JPG (206.8 KiB) Viewed 1263 times
- test.FCStd
- (5.31 KiB) Downloaded 11 times
Design456 Direct Modeling. Coin3D GUI Toolkit. Objects get simplified.
https://github.com/MariwanJ/Design456 - https://wiki.freecadweb.org/Design456_Workbench
https://www.youtube.com/watch?v=6agcHPd ... utbTDH93m_
Re: Would you please let me know why it is wrong?
Can confirm your object is a shell. Just "drill" it by cutting a box or cylinder and you'll see.
Maybe it comes from the way you create it, but hard to say without any more clue.
soldObjShape = _part.Solid(_part.Shell(_resultFace))
newObj = App.ActiveDocument.addObject("Part::Feature","comp")
newObj.Shape = soldObjShape
newObj = self.sewShape(newObj)
newObj = self.setTolerance(newObj)
for face in self.newFaces:
App.ActiveDocument.removeObject(face.Name)
Those 2 lines don't make much sense ATM as they are redefining your 'newObj' variable with some functions that I don't see (don't know type of 'self' and if functions are native or custom).
Part.show(Part.Solid(App.ActiveDocument.Solid.Shape))
BTW : Defeaturing tells you "Solid" because it is the name of the object, not because it is an actual solid.
def setTolerance(self, sel):
try:
if hasattr(sel, 'Shape'):
ns = sel.Shape.copy()
new_tol = 0.001
ns.fixTolerance(new_tol)
sel.ViewObject.Visibility = False
sl = App.ActiveDocument.addObject("Part::Feature", "Solid")
sl.Shape = ns
g = Gui.ActiveDocument.getObject(sel.Name)
g.ShapeColor = sel.ViewObject.ShapeColor
g.LineColor = sel.ViewObject.LineColor
g.PointColor = sel.ViewObject.PointColor
g.DiffuseColor = sel.ViewObject.DiffuseColor
g.Transparency = sel.ViewObject.Transparency
App.ActiveDocument.removeObject(sel.Name)
sl.Label = 'Extended'
return sel
except Exception as err:
App.Console.PrintError("'sewShape' Failed. "
"{err}\n".format(err=str(err)))
exc_type, exc_obj, exc_tb = sys.exc_info()
fname = os.path.split(exc_tb.tb_frame.f_code.co_filename)[1]
print(exc_type, fname, exc_tb.tb_lineno)
# Based on the sewShape from De-featuring WB,
# but simplified- Thanks for the author
def sewShape(self, sel):
"""[Fix issues might be in the created object]
Args:
sel ([3D Object]): [Final object that needs repair.
Always new object creates as result of sew]
try:
sh = sel.Shape.copy()
sh.sewShape()
sl = App.ActiveDocument.addObject("Part::Feature", "compSolid")
sl.Shape = sh
g = Gui.ActiveDocument.getObject(sl.Name)
g.ShapeColor = Gui.ActiveDocument.getObject(sel.Name).ShapeColor
g.LineColor = Gui.ActiveDocument.getObject(sel.Name).LineColor
g.PointColor = Gui.ActiveDocument.getObject(sel.Name).PointColor
g.DiffuseColor = Gui.ActiveDocument.getObject(
sel.Name).DiffuseColor
g.Transparency = Gui.ActiveDocument.getObject(
sel.Name).Transparency
return (sl)
I tested in Part WB the tool - >Make Solid .. it convert it to solid .. but I do the same sequence that tool tells me.
IMO, setTolerance returns 'sel' instead of 'sl'.
- Shalmeneser
Could you choose more specific title for your post, please ?
Yes you are right.
But for fixing the solid problem .. I needed to recreate a solid object again. Seems that sew or tolerance shapes are not solid. Regarding the Defeature.. I was not clear but I used the checking function for solid .. so it was telling me that it was ok .. you can try it.
Here my final code which works.
def recreateObject(self):
# FIXME:
# Here we have
# We try to create a wire-closed to replace the sides we delete.
# This will be way to complex . with many bugs :(
try:
App.ActiveDocument.removeObject(self.newEdge.Name)
_result = []
_resultFace=[]
_result.clear()
for faceVert in self.savedVertices:
convert = []
for vert in faceVert:
convert.append(vert.Point)
_Newvertices = convert
newPolygon = _part.makePolygon(_Newvertices, True)
convert.clear()
newFace = _part.makeFilledFace(newPolygon.Edges)
if newFace.isNull():
raise RuntimeError('Failed to create face')
nFace = App.ActiveDocument.addObject("Part::Feature", "nFace")
nFace.Shape = newFace
_result.append(nFace)
_resultFace.append(newFace)
self.newFaces = _result
solidObjShape = _part.Solid(_part.Shell(_resultFace))
newObj = App.ActiveDocument.addObject("Part::Feature", "comp")
newObj.Shape = solidObjShape
solidObjShape = _part.Solid(newObj.Shape)
final = App.ActiveDocument.addObject("Part::Feature", "Extended")
final.Shape = solidObjShape
App.ActiveDocument.removeObject(newObj.Name)
App.Console.PrintError("'recreate Object' Failed. "
Note:
Unfortunately, Part.Show doesn't return the created object. Which is a big problem .. You cannot use it in python. How can you find the created object? it is impossible if you think general.
sorry, you see it became a long title.Shalmeneser wrote: ↑Thu Dec 02, 2021 5:35 pm Could you choose more specific title for your post, please ?
- Shalmeneser
No problem. It will be better for memory and future research.
