wmayer wrote: ↑Sat Jan 15, 2022 12:25 pm
... but this probably should implemented as a separate feature as otherwise the Pad dialog will be too overloaded.
I think it would be beneficial to not having this as a separate feature creating a solid, but rather as one creating a set of wires again. This way it can be used in combination with all existing features working on wires (Pad, Pocket, Revolution, Groove, ...)
Here is a mock how this could present itself in the tree:
- Thickness2DSketchPadMock.png (21.47 KiB) Viewed 1918 times
Such a hypothetical "Thickness2D" could be similar to
Part Offset2D, but producing not only one offset, but two: one on each side of the referenced lines.
