Should copy in move clone be called?
thomas-neemann
Post by thomas-neemann »
a "copy" of mov behaves like a clone
move-copy-paste.FCStd
(10.24 KiB) Downloaded 8 times
ich biete freecad online-support an, als mini-job
VHS Freecad Aufbaukurs
https://www.vhs-lingen.de/programm/beru ... 012#inhalt
my workflow is optimized for speed, not for parametric
Re: Should copy in move clone be called?
thomas-neemann wrote: Fri Sep 23, 2022 7:27 am a "copy" of mov behaves like a clone
No, you can e.g. change the length of a copied line, which you cannot do with a clone.
thomas-neemann
chrisb wrote: Fri Sep 23, 2022 9:29 am ...
Yes thats right. should independent circles then be generated?
thomas-neemann wrote: Fri Sep 23, 2022 9:44 am Yes thats right. should independent circles then be generated?
What do you mean by "should"? They are independent here. What exactly is your concern?
thomas-neemann
chrisb wrote: Fri Sep 23, 2022 10:02 am ...
in my opinion a copy of circle001 creates circle002
a "clone" would stay at circle001
thomas-neemann wrote: Fri Sep 23, 2022 10:07 am in my opinion a copy of circle001 creates circle002
Sorry, I don't understand. Would you mind losing a few more words?
You copy Circle and you get a new object Circle001 in a new place which happens to have the same radius.
You copy Circle001 and you get a new object Circle002 in a new place which happens to have the same radius as Circle001. If you have changed the radius - or any other property - Circle002 would copy that changed value.
thomas-neemann
chrisb wrote: Fri Sep 23, 2022 10:33 am ...
if someone wants to create specific, independent copies (which can be changed later independently of one of them) it seems to work with move copy for lines, circles, etc. with a cut, for example, it doesn't seem to work. this is confusing in my opinion. if it were uniform it wouldn't confuse.
adrianinsaval
Post by adrianinsaval »
that's because you are copying the cut operation only, not it's children. They aren't clones either because it's still referencing the same objects.
thomas-neemann
adrianinsaval wrote: Fri Sep 23, 2022 11:25 am that's because you are copying the cut operation only, not it's children. They aren't clones either because it's still referencing the same objects.
Oh thank you. I was asked this in my freecad training course. To keep things simple, I will advise against the copy option in move and recommend using a clone or copy-paste copy, depending on how you want it to behave later.
