Plugin Loader
triplus
Re: Plugin Loader
Postby triplus » Fri Nov 20, 2015 1:11 am
I was wondering if using something like GitPython would make sense here? Therefore the updated database would be GitHub repository and macros, stylesheets, modules... would be "installed" to appropriate (local) user folders (Macro folder, Gui folder, Mod folder) by issuing git clone/git pull requests? Meta data repository could be hosted on GitHub for now and it would be nice if some additional information and maybe to show additional image would be supported directly in Plugin Loader.
I read the discussion:
viewtopic.php?f=21&t=13226
As for supporting "dropbox, website blog/forum entries" as software sources and trying to solve dependencies of installed software with Plugin Loader... To me it sounds like a lot of work but not necessary a lot of additional benefits.
microelly2
Re: Plugin Loader
Postby microelly2 » Fri Nov 20, 2015 5:36 am
Some "technical" users will not use git buit only run CAD, so I made a version without the fine git support but of course having a switch that detects an installed git client and uses the power of git pull will improve performance espacially for large addons like the freecad library and cadquery.
I will think about how to add git components as "plugins" too.
microelly2
Re: Plugin Loader
Postby microelly2 » Tue Dec 08, 2015 7:51 pm
I have started a branch https://github.com/microelly2/freecad-p ... /localdirs
which will only work inside UserAppData (~/.FreeCAD on ubuntu)
Next steps:
rework pluginloaderconfig.yaml
automatic macro-menubar generation
triplus
Re: Plugin Loader
Postby triplus » Tue Dec 08, 2015 8:03 pm
Sounds good.
cox
Re: Plugin Loader
Postby cox » Wed Dec 09, 2015 10:45 am
That is good news. :)
serviteur
Re: Plugin Loader
Postby serviteur » Fri May 20, 2016 11:00 am
Hello microelly2,
I have problem with the Plugin Loader.
When I Copy and paste installer.py into the FreeCAD python console window Freecad doesn't work.
download/file.php?mode=view&id=23306
Linux note
I install yaml
 sudo apt-get install python-yaml
I created a directory: /usr/lib/freecad/Mod/plugins/
and
 sudo chmod a+rw /usr/lib/freecad/Mod/plugins/
download/file.php?mode=view&id=23305
download/file.php?mode=view&id=23304
How to solved it?
OS: Ubuntu 16.04 LTS
Version: 0.16.6703 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.11+
OCC version: 6.8.0.oce-0.17
microelly2
Re: Plugin Loader
Postby microelly2 » Fri May 20, 2016 11:45 am
I have changed the installation directory to the users home:
It's now
$HOME/.FreeCAD/Mod/plugins
Move the plugins folder to this and it should work
EDIT: You have to use the localdirs branch:
serviteur
Re: Plugin Loader
Postby serviteur » Fri May 20, 2016 11:55 am
OK; but a don't have /Mod in
/home/serviteur/.FreeCAD
How to restore rights directory /usr/lib/freecad/Mod/plugins and /usr/lib/freecad/Mod/ after the command?
serviteur
Re: Plugin Loader
Postby serviteur » Fri May 20, 2016 12:47 pm
I created /Mod and I work now.
cement_head
Re: Plugin Loader
Postby cement_head » Mon Apr 10, 2017 9:03 pm
Okay, got this fixed now on Ubuntu. Can you please change the documentation on GitHub and the PluginLoader FreeCAD page?
Thanks,
Andor
