0.16 Features We'd Like To See
godblessfq
Re: 0.16 Features We'd Like To See
Postby godblessfq » Sat Oct 24, 2015 1:49 pm
Hello everyone,
Maybe the preference dilogue can be improved.
I'd like the tool icon size to have more options. I want the size 20 and it's not in the dropdown list.
I have to modify user.cfg file in my home folder:
<FCInt Name="ToolbarIconSize" Value="20"/>
But that is overwriten the next time preference is set and I need to change it back again.
Why not just left it as an editable box?
OS: Debian GNU/Linux 8.0 (jessie)
Version: 0.16.5632 (Git)
godblessfq
Postby godblessfq » Tue Nov 17, 2015 9:01 pm
Maybe the shape2Dview in the draft workbench should use the view direction as the default projection direction.
cox
Postby cox » Tue Nov 17, 2015 10:07 pm
godblessfq wrote:Maybe the shape2Dview in the draft workbench should use the view direction as the default projection direction.
Sound intuitive :) +1
microelly2
Postby microelly2 » Tue Nov 17, 2015 11:01 pm
import math
import FreeCAD,Draft
camera = FreeCADGui.ActiveDocument.ActiveView.getCameraNode()
a=str(camera.position.getValue().toString())
al=a.split(' ')
v=Draft.makeShape2DView(FreeCAD.ActiveDocument.YourObject)
v.Projection=(float(al[0]),float(al[1]),float(al[2]))
I still have to understand the rotation angle - tomorrow.
godblessfq
Postby godblessfq » Wed Nov 18, 2015 1:52 pm
Thank you for the macro. I am gonna to replace the shape2dview tool with it. :)
mario52
Postby mario52 » Thu Nov 19, 2015 3:53 pm
hi microelly2
i modify your code for use with one object selected
I would put it in the wiki, what name can we give it
if you agree !
import math
try:
    sel = FreeCADGui.Selection.getSelection()[0]
    al=a.split(' ')
    v=Draft.makeShape2DView(FreeCAD.ActiveDocument.getObject(sel.Name))
except Exception:
    print "Select one object"
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
microelly2
Postby microelly2 » Thu Nov 19, 2015 8:46 pm
Good idea mario,
I would it call 2DView and store into https://github.com/FreeCAD/FreeCAD-macros
There is already a macro Foto.FCMacro, which makes a picture (still works from top view)
Do you have access to that git or I can check it in.
I want to make some more modification next:
1. rotate to view in a way that the real z-axis maps to the y-axis of the 2dView
2. and we should make the exeption handling stronger.
def errorDialog(msg):
    diag = QtGui.QMessageBox(QtGui.QMessageBox.Critical,u"Error Message",msg )
    diag.setWindowFlags(PySide.QtCore.Qt.WindowStaysOnTopHint)
    diag.exec_()
except Exception:
    errorDialog( "Select one object")
mario52
Postby mario52 » Fri Nov 20, 2015 9:52 am
hi
microelly2 wrote:I would it call 2DView
ok and the icon ?
microelly2 wrote:Do you have access to that git or I can check it in.
no
mario
microelly2
Postby microelly2 » Fri Nov 20, 2015 1:40 pm
I don't see a simple solution to get the right direction of generated figure by a script.
somewhere behind Drawing.projectEx and HLRAlgo_Projector may be a way to get the things right,
but for me a running script is better than hours to read.
So my proposal: Create a Draft.Clone of the part, Rotate this clone to get the right view from +z
and then create the shape2View from this clone.
May be someone can tell me how the rotation logic is :?
(otherwise I will put the proposal into a macro)
