The Properties section of each page I think is wrong.
Fasteners workbench based on screw-maker
Re: Fasteners workbench based on screw-maker
Re: Fastener WB, clicking on "Counter Sunk" hangs FreeCAD
Can anyone else reproduce this ?Qutub Abro wrote: ↑Wed Mar 31, 2021 12:59 am I have FreeCAD V0.19 installed. I used "Fastener WB" to make a counter sunk hole in my FreeCAD design. But when I click on the Diameter to change it to M4, The FreeCAD hangs.
Fastener WB was working fine on FreeCAD V0.18.
Edit: I merged this from a separate post
Why not just use the PartDesign Hole feature?Qutub Abro wrote: ↑Wed Mar 31, 2021 12:59 am I have FreeCAD V0.19 installed. I used "Fastener WB" to make a counter sunk hole in my FreeCAD design. But when I click on the Diameter to change it to M4, The FreeCAD hangs.
Here is a M4 course threaded and thread modeled countersunk hole feature in a Pad, just as a simple demo.
not really since the hole is now not part of the Body.hpbmo wrote: ↑Wed Mar 31, 2021 11:04 am Here it works with FASTENERSWB_VERSION = 'V0.3.32'
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: German/Switzerland (de_CH)
Here is the file, I toggled "Model Thread" property to "false" to make the file small enough to upload here. Just toggle it to "true" if you want to 3d print the thread or similar.
you can see the property in the property editor in combo view in this screen shot.
Here is the same file as above but with the Model thread property toggled to true.
Thanks for the quick reply.
Here is more information about what happened and what I did to overcome it.
Fastener WB had been working fine for me since I installed it about couple of weeks back, on FreeCAD 0.18.4
I removed FreeCAD 0.18.4, and installed 0.19 version
I was trying to do a Counter sunk Chamfer on a hole:
1. I tried to select the edge and then click on Counter Sunk Chamfer button. Its own parameter setting window will appear. But selected edge would not the ticked Counter Sunk Chamfer window. As soon as I click on the it to change any parameter, FreeCAD would hang.
2. Even if I select the part, then click on Counter Sunk Chamfer button. The screen will appear, but when I select the edge on the part, it would not be ticked in the Counter Sunk Chamfer. Then I try to click on it, the FreeCAD would hang.
I removed FreeCAD 0.19, and installed 0.18.4. Then added Fastener WB. It is working now. It means, the issue is between Fastener WB and FreeCAD 0.19.
Excellent workbench, but it has two limitations as far as my needs
1)
The smallest metric thread is M1.6
I need fasteners smaller than that, for example:
https://ghw-modellbau.de/index.php?cPat ... anguage=de
or even smaller:
https://ghw-modellbau.de/index.php?cPath=4_5_7_103
2)
I need "threaded rod for tapping holes" and "threaded tube for cutting external threads" in a range of ME threads:
https://www.gewinde-normen.de/en/me-thread.html
I had a go (as discussed in this thread: https://forum.freecadweb.org/viewtopic. ... 6&start=20)
and was able to add smaller metric threads, but I stumbled beyond that both on understanding the threads databases and how to add what I wanted.
I tried to seek help by raising an issue on Github:
https://github.com/shaise/FreeCAD_FastenersWB/issues/88
I am more than happy to do all the work with adding of the data, but need help to get going.
Is there anybody out there who can help, please?
1)
or even smaller:
2)
Re: 1/4 bolt problem - Shape is not a shell
This is a great add on. Very impressive. Thanks for all the work.
The imperial bolts have an issue with 1/4 type = ASMEB18.2.1.6 UNC Machine Screws. The other sizes seem to work correctly.
10:13:07 Traceback (most recent call last):
File "C:\Users\Colin\Downloads\FreeCAD-0.19.1.a88db11\Config\AppData\Roaming\FreeCAD\Mod\fasteners\FastenersCmd.py", line 160, in execute
s = screwMaker.createFastener(fp.type, d, l, threadType, True)
File "C:\Users\Colin\Downloads\FreeCAD-0.19.1.a88db11\Config\AppData\Roaming\FreeCAD\Mod\fasteners\ScrewMaker.py", line 338, in createFastener
return self.createScrew(type, diam, len, threadType, shapeOnly)
File "C:\Users\Colin\Downloads\FreeCAD-0.19.1.a88db11\Config\AppData\Roaming\FreeCAD\Mod\fasteners\screw_maker.py", line 941, in createScrew
screw = self.makeIso4017_2(ST_text, ND_text,l)
File "C:\Users\Colin\Downloads\FreeCAD-0.19.1.a88db11\Config\AppData\Roaming\FreeCAD\Mod\fasteners\screw_maker.py", line 1836, in makeIso4017_2
rthread = self.makeShellthread(dia, P, halfturns, True, offSet)
File "C:\Users\Colin\Downloads\FreeCAD-0.19.1.a88db11\Config\AppData\Roaming\FreeCAD\Mod\fasteners\screw_maker.py", line 3362, in makeShellthread
TheShell = Part.Shell(TheFaces)
<class 'Part.OCCError'>: Shape is not a shell
OS: Windows 10 Version 2009
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
It isn't an issue with the workbench as such, the specific screws work with thread = true using OCC 7.3.0 but don't using OCC 7.5.0
OS: Windows 7 SP 1 (6.1)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.6.8
Qt version: 5.12.1
