Fasteners workbench based on screw-maker
easyw-fc
Re: Fasteners workbench based on screw-maker
Postby easyw-fc » Thu Aug 30, 2018 1:42 pm
shaise wrote:
Thu Aug 30, 2018 1:08 pm
the workbench works on ver 0.18.
use the addon manager, and install "fasteners" workbench
there are some issue only on py3/qt5
Ruanova
Postby Ruanova » Thu Aug 30, 2018 2:17 pm
Thanks, solved
The problem was that I used FreeCAD_0.18.14495_Conda_Py3QT5-WinVS2016_x64.
With FreeCAD_0.18.14495_x64_dev_win works perfectly
triplus
Postby triplus » Thu Aug 30, 2018 3:09 pm
Hi @Ruanova
The point of Py3(Qt5) builds provided on the releases page is to get more verbose end user feedback. Regarding porting to Py3 effort. Therefore best if you provide the error message you are getting when using the Py3 build. As eventually it will need to get fixed.
GlouGlou
Postby GlouGlou » Fri Nov 02, 2018 9:38 pm
These cap nuts are missing. :roll:
mariusz.dec
Postby mariusz.dec » Thu Mar 21, 2019 12:14 pm
Hi all,
currently I would like to change actual design from 0.17 to 0.18 but I am using a lot of PEMs, screws, studs etc.
Unfortunatelly STUDS doesn't work for me - I have checked it on W10 64 Pro and on W7 64 Pro, same problem.
Stud appears on the list but isn't visible.
Regards
Mariusz
Report from (W7)
Running the Python command 'FSStud' failed:
File "C:\Program Files\FreeCAD 0.18\Mod\FreeCAD_FastenersWB-master\PEMInserts.py", line 591, in Activated
FastenerBase.FSGenerateObjects(FSStudObject, "Stud")
File "C:\Program Files\FreeCAD 0.18\Mod\FreeCAD_FastenersWB-master\FastenerBase.py", line 356, in FSGenerateObjects
objectClass(a, selObj)
File "C:\Program Files\FreeCAD 0.18\Mod\FreeCAD_FastenersWB-master\PEMInserts.py", line 531, in __init__
obj.addProperty("App::PropertyEnumeration","length","Parameters","Standoff length").length = fhGetAllLengths(FHDiameters[1])
File "C:\Program Files\FreeCAD 0.18\Mod\FreeCAD_FastenersWB-master\PEMInserts.py", line 519, in fhGetAllLengths
list.sort(cmp = FastenerBase.NumCompare)
'cmp' is an invalid keyword argument for this function
shaise
Postby shaise » Thu Mar 21, 2019 1:32 pm
1. can you post your exact freecad version?
goto help -> about FreeCad and click "copy to clipboard". then paste here.
2. are you sure you have the latest fastener workbench? (use add-on manager to update)
mariusz.dec
Postby mariusz.dec » Fri Mar 22, 2019 4:33 pm
Hi Shaise.
My FreeCad version at home:
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 3.6.6
Qt version: 5.6.2
Locale: Polish/Poland (pl_PL)
Version of Fasteners...
Here at home I have downloaded Fasteners via AddOn manager and it works now.
At work I have environment isolated from Internet, so I see that I have old version.
I am sorry. My fault :(.
I am working in small screws, so I did small changes to PEMInserts.py.
It works, but please check if my data for M2 and M2.5 are correct.
# PEM Self Clinching standoffs types: SO/SOS/SOA/SO4
SOLengths = {'2':0, '3':0, '4':0, '6':0, '8':0, '10':4, '12':4, '14':4, '16':8, '18':8, '20':8, '22':11, '25':11}
#BSLengths = {'6':1.6, '6':2.2, '6':3.2, '8':4, '10':4, '12':5, '14':6.5, '16':6.5, '18':9.5, '20':9.5, '22':9.5, '25':9.5}
SODiameters = ['Auto', 'M2', 'M2.5', 'M3', '3.5M3', 'M3.5', 'M4', 'M5' ]
SOPEMTable = {
# B, C, H, d, Lmin, Lmax
'M2': (2.2, 4.2, 4.8, 1.6, 3, 18),
'M2.5': (2.7, 4.2, 4.8, 2.2, 3, 18),
'M3': (3.2, 4.2, 4.8, 2.5, 3, 18),
'3.5M3':(3.2, 5.39, 6.4, 2.5, 3, 25),
'M3.5': (3.9, 5.39, 6.4, 2.9, 3, 25),
'M4': (4.8, 7.12, 7.9, 3.3, 3, 25),
'M5': (5.36, 7.12, 7.9, 4.2, 3, 25)
And another thing - because of my works I am using countersink screws with very low profile for 1 mm metal sheets - like DIN965A
https://www.tme.eu/gb/details/b2x3_bn66 ... d/1412558/
Is it possible to adapt ScreMaker.py to to make such screws?
Regards
Mariusz
Joel_graff
Postby Joel_graff » Fri Mar 22, 2019 9:30 pm
Just added the workbench to the v0.19 release notes.
https://www.freecadweb.org/wiki/Releas ... al_Modules
Postby Kunda1 » Tue May 14, 2019 3:10 pm
I moved the workbench out of of the wiki sandbox. New URL is https://www.freecadweb.org/wiki/Fasteners_Workbench aka Fasteners Workbench
FYI @Joel_graff, I updated the Release_notes_0.19#Additional_Modules with the link.
VanLaser
Postby VanLaser » Thu Jun 06, 2019 9:44 am
Hi, hope this is the right thread to ask my question!
First, thanks for all the work on this workbench, I use it for my 3d printer projects, and results are very good :)
I'm normally creating first my model as usual ("Part Design", pads, holes etc.) and afterwards I switch to the "Fasteners" workbench and add a "variable length threaded rod for holes" object for each hole I've created, place the rods in the holes to match, then (in the "Part" workbench) I make a join of all the rods, and finally cut this join from my model so that I'm left with the threaded holes in my model. All this works alright, my only time consuming step is the one in which I have to move the rods exactly where the holes are, and my question is: is there an alternative (i.e. faster) way to do that, or - alternatively - can this step be automated? Something like - "configure this rod to exactly match-diameter-and-overlap this hole"? Ideally, when one creates a hole and checks the "threaded" property, this entire process (place a matching rod, subtract) should happen automatically, but the next best thing would be the automated matching on request. Would something like that be possible?
