OpenNURBS 3DM file support?
keithsloan52
Re: OpenNURBS 3DM file support?
Postby keithsloan52 » Tue Mar 24, 2020 3:40 pm
Okay fixed a number of errors but still get
Import 3DM file : /home/keith/Example_3dm_files/V6/v6_rhino_logo.3dm
Import3DM Version 0.01
Brep
is solid : True
is manifold : True
is surface : False
has 4 faces
has 4 surfaces
has 6 edges
<rhino3dm._rhino3dm.BrepFace object at 0x7f5bd1d63ed8>
None
  File "/home/keith/.FreeCAD/Mod/ImportNURBS/freecad/importNURBS/import3DM.py", line 27, in open
    process3DM(doc,filename)
  File "/home/keith/.FreeCAD/Mod/ImportNURBS/freecad/importNURBS/import3DM.py", line 165, in process3DM
    fi.parse_objects(doc)
  File "/home/keith/.FreeCAD/Mod/ImportNURBS/freecad/importNURBS/import3DM.py", line 55, in parse_objects
    obj = self.import_geometry(doc, self.f3dm.Objects[i].Geometry)
  File "/home/keith/.FreeCAD/Mod/ImportNURBS/freecad/importNURBS/import3DM.py", line 73, in import_geometry
    shapes.append(s.toShape())
<class 'AttributeError'>: 'NoneType' object has no attribute 'toShape'
Need a break for today - back tomorrow
Chris_G
Postby Chris_G » Tue Mar 24, 2020 4:15 pm
It's an indentation bug.
PR #1
keithsloan52
Postby keithsloan52 » Tue Mar 24, 2020 4:25 pm
Thanks - Committed your Pull request - rhino_logo now loads :-)
keithsloan52
Postby keithsloan52 » Tue Mar 24, 2020 7:46 pm
Hi Chris ( @Chris_G) If I look at what the Rhino file creates I see it has a number of Faces(Objects), but they seem to have been created as BSplineSurface objects. The Faces Objects don't seem to have any properties that can be changed/edited.
Would I be correct in that FreeCAD does not really support BSplineSurface Objects that one can change property and it redraw.
I am thinking one could create support for such objects with Part::PythonObjects.
There seem to be a number of workbenches that implement curves and surfaces, are you aware if they have implemented a BSplineSurface object?
