When I want to move a line, the constraint doesn't seem to work anymore and it FreeCAD will move another line too when I move the selected line I want to displace on the canvas.
The video will show you.
https://www.dropbox.com/s/bw7zeqc8x0gsu ... D.mp4?dl=0
OS: Mac OS X
Version: 0.16.4945 (Git)
Hash: 6cd9220079a1efb1a2f33842fa614521a31bf0d5
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
FreeCAD move tool will not move the right line.
- DeepSOIC
Re: FreeCAD move tool will not move the right line.
Are you talking about a small shift of that vertical line that spans the whole height of the screen? That looks a bit strange.M-Rick wrote:FreeCAD will move another line too
I think, by saying "constraint", you mean "snapping". Constraints are in Sketcher. You are in Draft.M-Rick wrote: the constraint doesn't seem to work anymore
- DeepSOIC
About that vertical line. I just noticed that recompute button is active, and becomes gray as you finish the move. So the line probably moves as a result of recompute, and may have nothing to do with what you actually do. Click recompute button if you see it shining .
I am speaking about this toolDeepSOIC wrote:Are you talking about a small shift of that vertical line that spans the whole height of the screen? That looks a bit strange.M-Rick wrote:FreeCAD will move another line tooI think, by saying "constraint", you mean "snapping". Constraints are in Sketcher. You are in Draft.M-Rick wrote: the constraint doesn't seem to work anymore
http://www.freecadweb.org/wiki/index.ph ... Draft_Move
Everything was working well until now. It is like a cache was affected and created this bug I never saw before.
Yes, I was thinking of snapping, those tools http://www.freecadweb.org/wiki/index.ph ... Draft_Snap
Where is this button?DeepSOIC wrote:About that vertical line. I just noticed that recompute button is active, and becomes gray as you finish the move. So the line probably moves as a result of recompute, and may have nothing to do with what you actually do. Click recompute button if you see it shining .
- DeepSOIC
M-Rick wrote:Where is this button?
