STEP importer out of date?
plaes
Postby plaes » Wed Dec 16, 2015 2:57 pm
Hi!
I recently had to import some STEP models made with some other CADs and noticed that FreeCAD's STEP importer doesn't do the grouping of the subelements.
Then I digged into the sources a bit and noticed it to be using code from http://stepcode.org/ with github repository here: https://github.com/stepcode/stepcode
Unfortunately I haven't yet figured out how FreeCAD and stepcode work together.
I also filed bug report with sample file here: http://freecadweb.org/tracker/view.php?id=2369
ickby
Re: STEP importer out of date?
Postby ickby » Wed Dec 16, 2015 4:11 pm
Freecad does not use stepcode but the occ step importer. And it does not group the imports because there is no functionality for that available in Freecad, hence groups are ignored.
plaes
Postby plaes » Wed Dec 16, 2015 4:37 pm
ickby wrote:Freecad does not use stepcode but the occ step importer. And it does not group the imports because there is no functionality for that available in Freecad, hence groups are ignored.
Ok, thanks for the info.
I was looking at the files under src/Mod/Import/App which caused the confusion.
Site Admin
Postby wmayer » Wed Dec 16, 2015 6:21 pm
In FreeCAD there is a hidden function to get the structure of a STEP or IGES file (or better the structure of the ocaf document). You can load it with:
import ImportGui
ImportGui.ocaf("arietta.step")
which shows a tree with all the content. Does anybody know how to get the grouping information out of this?
@plaes in the bug report you said that SW shows the grouping properly. How many groups are there and how many levels? Maybe an image would help.
I tried the file with CADExchanger which shows also some group structure but they are labeled "=> [0:1:1:2]" and so on but not "Board", "C57", ...
plaes
Postby plaes » Wed Dec 16, 2015 7:30 pm
I added screenshot to the bug.
Tree looks basically like this:
1. Board
2. C57 (open)
2.1 61005408<1> (closed)
2.2 603788960<1> (open)
2.2.1 Extruded_2
2.3 603788960<2> (closed)
2.4 61005280
2.5 61005408
3. C56 (closed)
4. C55 (closed)
Site Admin
Postby wmayer » Wed Dec 16, 2015 8:24 pm
OK, thanks.
easyw-fc
Postby easyw-fc » Tue Dec 22, 2015 11:39 pm
hi @plaes,
I know that will not solve the prob of previous exported files, but if you create a union of each part model, instead of group, your assemblies will be easier handled...
I create a script to export kicad boards to MCAD STEP model, and to have a sort of hierarchical assembly, I use to model each part as a single fused obj...
the you will have board and parts
If you download the kicad stepup demo
http://sourceforge.net/projects/kicadstepup/
there you can find a self contained prj, with a board and assemblies generated in FreeCAD as a pseudo hierarchical structure...
and here a picture of the structure in solidworks
Postby Kunda1 » Tue Jul 11, 2017 11:04 am
import ImportGui
vejmarie wrote:ping
@vejmarie can you weigh in on this?
vejmarie
Postby vejmarie » Tue Jul 11, 2017 12:57 pm
import ImportGui
vejmarie wrote:ping
I think this stuff shall be addressed with PR #871. Let's wait to see if it could be merged in master and if the issue is still there. OCAF is a great document format to manage STEP, took me some time to learn it but this is efficient. the [0:1:1:2] is a coding for a tree. Like 0-> Root node ->1 first element at level 1 -> 1 first element at level 2 -> second element at level 3.
easyw-fc
Postby easyw-fc » Tue Jul 11, 2017 2:02 pm
in general if the problem is that the importer is not grouping elements, loading those in FLAT mode, the STEP importer has solved this issue already with previous PRs. Moreover the latest PR is solving also the Hierarchy in exporting the file.
Unfortunately the OP didn't upload the file to test, but at this post
https://forum.freecadweb.org/viewtopic.php?f=9&t=23371
I'm going to load the screenshots displaying exactly the hierarchy both in loading and writing STEP files
Maurice
