labels for Sweep and Loft operations
piffpoof
Postby piffpoof » Mon Jan 25, 2016 6:28 am
After 18 months using FreeCAD I have just figured something out, or at least think I have.
With respect to the "Utility to Sweep" and "Utility to Loft" operations of the Part Workbench, when making a Sweep or Loft operation through the GUI, there are two selection panels with 4 movement arrows between them. The labels above the two panels are:
"Vertex/Edge/Wire/Face Loft"
and
"Vertex/Edge/Wire/Face Sweep"
These labels never made sense to me until this morning I was working on a question posted on the forum. I had figured out how they worked but couldn't make any sense of the actual wording.
Might I suggest that the label over the lefthand panel read:
"Vertices/Edges/Wires/Faces"
or possibly better:
"Items available for Loft operation:
(Vertices/Edges/Wires/Faces)
And over the righthand panel:
"Items selected for Loft"
With the Sweep operation the same label text but the word "Sweep" substituted for the word "Loft"
I think this change would make the intent and purpose of the selection panels more obvious.
Dean
jmaustpc
Re: labels for Sweep and Loft operations
Postby jmaustpc » Mon Jan 25, 2016 9:35 am
piffpoof wrote:"Items available for Loft operation:
(Vertices/Edges/Wires/Faces)"
I think the correct term for these would be "profiles", at least with a Sweep they are called "profiles" and a sweep of course also has a "path".
The list in theory at least, only provides "valid" profiles but there are exceptions and complications, for example a vertex/point can only be a first or last profile not for example 2nd of 3.
piffpoof
Postby piffpoof » Mon Jan 25, 2016 2:46 pm
jmaustpc wrote: I think the correct term for these would be "profiles", at least with a Sweep they are called "profiles" and a sweep of course also has a "path".
thanks Jim
I amend the suggestion to have the labels read:
On the lefthand Loft panel:
"Profiles available for Loft operation:
And the righthand Loft panel:
"Profiles selected for Loft"
On the lefthand Sweep panel:
"Profiles available for Sweep operation:"
And the righthand Sweep panel:
"Profile selected for Sweep"
NormandC
Postby NormandC » Sun Jan 31, 2016 12:18 am
I agree with this proposed change. But create an issue on Mantis because this topic will be overlooked/forgotten. Mantis' whole purpose is to track bugs, feature requests and proposals such as this one.
piffpoof
Postby piffpoof » Sun Jan 31, 2016 7:39 am
Done as issue #0002429
Listed as a "Feature Request" which seems a bit grandiose but there wasn't really any other option (Proposal might be a better fit)
Thanks for the reminder, I must admit I had forgotten about this one myself...
bill
Postby bill » Sun Jan 31, 2016 12:11 pm
Thanks @piffpoof of the Mare Nostrum, this was always confusing to me and a lot of other users I know! Thought is was one of those "Lost in Translation" things.
Bravo!
Postby Kunda1 » Mon Jan 30, 2017 8:10 pm
soft bump
Postby Kunda1 » Fri Feb 17, 2017 1:58 pm
NormandC wrote:I agree with this proposed change. But create an issue on Mantis because this topic will be overlooked/forgotten. Mantis' whole purpose is to track bugs, feature requests and proposals such as this one.
Do you still agree with this proposal ?
NormandC
Postby NormandC » Sat Feb 18, 2017 9:31 pm
Absolutely.
Postby Kunda1 » Fri Jun 16, 2017 3:50 pm
yorik wrote:ping
Care to weigh in?
