Ian
As mentioend in my last post, I had been trying to mesh within FreeCAD though the GMSHMacro.FCMacro that you recommended . The error ath ti got is the following:
<unknown exception traceback><type 'exceptions.SyntaxError'>: ('invalid syntax', ('/Users/JCarrington 1/Library/Preferences/FreeCAD/Macros_FreeCAD/Macros/GMSHMesh.FCMacro', 22, 18, 'gmsh_bin_other =
\xe2\x80\x9c/Applications/Gmsh.app/Contents/MacOS/gmsh
\xe2\x80\x9d\n'))
I do not know what is the source of the backslashes and appended fields (highlighted in red color above in the error message) at the beginning path ( \xe2\x80\x9c /Applications/…) and appended at the end of the path …/gmsh\ xe2\x80\x9d\n'. The appended field and baclashes are not part of the path to gmsh.
Had you seen this error before?
Do you have any suggestions on how can overcome the error and be able to mesh using gmsh?
Any help will be appreciated.
I searched and found this link which reports the same issue but I am not sure if thsi will fix the issue or will casue soem trroubleto my computer.
http://stackoverflow.com/questions/1728 ... after-upda
Thanks for the help.
My computer is a MAC OS X, Version 10.9.5.
I am running FreeCAD version 16.
I am using TextEdit as editor.
The path to where gmsh is in my computer is the one already mentioned in some post in this thread: /Applications/Gmsh.app/Contents/MacOS/gmsh
The Macro file that I edited to include the path where gmsh ( gmsh_bin_other = "/Applications/Gmsh.app/Contents/MacOS/gmsh") is the following:
# -*- coding: utf-8 -*-
# Mesh with GMSH inside of FreeCAD
# Author: Gomez Lucio
# Modified by: PrzemoF
# Modified by: Bernd Hahnebach (bernd@bimstatik.org)
# License: LGPL v 2.1
# Version: 04/07/2015
# CONFIGURATION - EDIT THE FOLLOWING LINE TO MATCH YOUR GMSH BINARY
gmsh_bin_linux = "/usr/bin/gmsh"
gmsh_bin_windwos = "C:\\Daten\\gmsh-2.10.0-Windows\\gmsh.exe"
#gmsh_bin_other = "/usr/bin/gmsh"
#Lorenzo changes
gmsh_bin_other = “/Applications/Gmsh.app/Contents/MacOS/gmsh”
# END CONFIGURATION
# START OF MACRO
from PySide import QtGui, QtCore
import Fem
import FemGui
import FemAnalysis
import FreeCAD
import FreeCADGui
import ImportGui
import Mesh
import subprocess
import sys
import tempfile
from platform import system
if system() == "Linux":
gmsh_bin = gmsh_bin_linux
path_sep = "/"
elif system() == "Windows":
gmsh_bin = gmsh_bin_windwos
path_sep = "\\"
else:
gmsh_bin = gmsh_bin_other
path_sep = "/"
class MeshGmsh(QtGui.QWidget):
def __init__(self):
super(MeshGmsh, self).__init__()
self.initUI()
def __del__(self):
return
def initUI(self):
# Mesh dimension
self.rb_1D = QtGui.QRadioButton(" 1D", self)
self.rb_2D = QtGui.QRadioButton(" 2D", self)
self.rb_3D = QtGui.QRadioButton(" 3D", self)
self.rb_3D.setChecked(QtCore.Qt.Checked)
# Optimized:
self.cb_optimized = QtGui.QCheckBox(" Optimized", self)
self.cb_optimized.setChecked(QtCore.Qt.Checked)
# Create Mechanical Analysis from mesh
self.cb_mec_anal = QtGui.QCheckBox(" Create Mechanical Analysis from mesh",self)
#self.cb_mec_anal.setChecked(QtCore.Qt.Checked)
# Algorithm:
self.l_algorithm = QtGui.QLabel("Algorithm ", self)
self.cmb_algorithm = QtGui.QComboBox(self)
self.algorithm_list = [self.tr('iso'), self.tr('netgen'), self.tr('tetgen'), self.tr('meshadapt'), ]
self.cmb_algorithm.addItems(self.algorithm_list)
self.cmb_algorithm.setCurrentIndex(1)
# Format:
self.l_format = QtGui.QLabel("Format ", self)
self.cmb_format = QtGui.QComboBox(self)
self.format_list = [self.tr('unv'), self.tr('stl'), self.tr('med')]
self.cmb_format.addItems(self.format_list)
self.cmb_format.setCurrentIndex(0)
self.stored_cmb_format_index = 0
# Element max size:
self.cb_max_elme_size = QtGui.QCheckBox(" Set maximum mesh element size",self)
self.cb_max_elme_size.setChecked(QtCore.Qt.Checked)
self.sb_max_element_size = QtGui.QDoubleSpinBox(self)
self.sb_max_element_size.setValue(5.0)
self.sb_max_element_size.setMaximum(10000000.0)
self.sb_max_element_size.setMinimum(0.00000001)
# Element min size:
self.cb_min_elme_size = QtGui.QCheckBox(" Set minimum mesh element size",self)
self.sb_min_element_size = QtGui.QDoubleSpinBox(self)
self.sb_min_element_size.setValue(1.0)
self.sb_min_element_size.setMaximum(10000000.0)
self.sb_min_element_size.setMinimum(0.00000001)
self.sb_min_element_size.setEnabled(False)
# Set Mesh Order:
self.cb_mesh_order = QtGui.QCheckBox(" mesh order",self)
self.cb_mesh_order.setChecked(QtCore.Qt.Checked)
self.sb_mesh_order = QtGui.QSpinBox(self)
self.sb_mesh_order.setValue(2)
self.sb_mesh_order.setMaximum(5)
self.sb_mesh_order.setMinimum(1)
# Other gmsh commands:
self.l_cmd_line_opt = QtGui.QLabel("Custom gmsh options ", self)
self.le_cmd_line_opt = QtGui.QLineEdit(self)
self.le_cmd_line_opt.setToolTip("Those option will be appended to gmsh command line call")
# Ok buttons:
self.okbox = QtGui.QDialogButtonBox(self)
self.okbox.setOrientation(QtCore.Qt.Horizontal)
self.okbox.setStandardButtons(QtGui.QDialogButtonBox.Cancel | QtGui.QDialogButtonBox.Ok)
# Web button
self.pb_web = QtGui.QPushButton(self)
self.pb_web.setText("gmsh options (web)")
# Layout:
layout = QtGui.QGridLayout()
layout.addWidget(self.rb_1D, 1, 0)
layout.addWidget(self.rb_2D, 1, 1)
layout.addWidget(self.rb_3D, 2, 0)
layout.addWidget(self.cb_optimized, 2, 1)
layout.addWidget(self.l_algorithm, 3, 0)
layout.addWidget(self.cmb_algorithm, 3, 1)
layout.addWidget(self.l_format, 4, 0)
layout.addWidget(self.cmb_format, 4, 1)
layout.addWidget(self.cb_max_elme_size, 5, 0)
layout.addWidget(self.sb_max_element_size, 5, 1)
layout.addWidget(self.cb_min_elme_size, 6, 0)
layout.addWidget(self.sb_min_element_size, 6, 1)
layout.addWidget(self.cb_mesh_order, 7, 0)
layout.addWidget(self.sb_mesh_order, 7, 1)
layout.addWidget(self.cb_mec_anal, 8, 0)
layout.addWidget(self.l_cmd_line_opt, 9, 0)
layout.addWidget(self.le_cmd_line_opt, 9, 1)
layout.addWidget(self.pb_web, 10, 0)
layout.addWidget(self.okbox, 10, 1)
self.setLayout(layout)
# Connectors:
QtCore.QObject.connect(self.okbox, QtCore.SIGNAL("accepted()"), self.proceed)
QtCore.QObject.connect(self.okbox, QtCore.SIGNAL("rejected()"), self.cancel)
self.pb_web.clicked.connect(self.open_gmsh_options)
self.cb_max_elme_size.stateChanged.connect(self.max_size_state)
self.cb_min_elme_size.stateChanged.connect(self.min_size_state)
self.cb_mesh_order.stateChanged.connect(self.mesh_order_state)
def max_size_state(self, state):
if state == QtCore.Qt.Checked:
self.sb_max_element_size.setEnabled(True)
else:
self.sb_max_element_size.setEnabled(False)
def min_size_state(self, state):
self.sb_min_element_size.setEnabled(True)
else:
def mesh_order_state(self, state):
self.sb_mesh_order.setEnabled(True)
else:
self.sb_mesh_order.setEnabled(False)
def open_gmsh_options(self):
import webbrowser
webbrowser.open('http://www.geuz.org/gmsh/doc/texinfo/gmsh.html#Command_002dline-options')
def cancel(self):
self.close()
d.close()
def proceed(self):
temp_file = tempfile.mkstemp(suffix='.step')[1]
selection = FreeCADGui.Selection.getSelection()
if not selection:
QtGui.QMessageBox.critical(None, "GMSHMesh macro", "An object has to be selected to run gmsh!")
return
# Export a part in step format
ImportGui.export(selection, temp_file)
selection_name = selection[0].Name
# Mesh temporaly file
file_format = self.cmb_format.currentText()
temp_mesh_file = tempfile.tempdir + path_sep + selection_name + '_Mesh.' + file_format
# OPTIONS GMSH:
clmax = self.sb_max_element_size.text()
clmin = self.sb_min_element_size.text()
cmd_line_opt = self.le_cmd_line_opt.text()
algo = self.cmb_algorithm.currentText()
mesh_order = self.sb_mesh_order.text()
if self.cb_optimized.isChecked():
cmd_optimize = ' -optimize'
else:
cmd_optimize = ''
if self.rb_3D.isChecked():
dim = ' -3 '
if self.rb_2D.isChecked():
dim = ' -2 '
if self.rb_1D.isChecked():
dim = ' -1 '
if self.cb_max_elme_size.isChecked():
max_size = ' -clmax ' + clmax
else:
max_size = ''
if self.cb_min_elme_size.isChecked():
min_size = ' -clmin ' + clmin
else:
min_size = ''
if self.cb_mesh_order.isChecked():
order = ' -order ' + mesh_order
else:
order = ''
options = ' -algo ' + algo + max_size + min_size + cmd_optimize + order + cmd_line_opt
# RUN GMSH
command = gmsh_bin + ' ' + temp_file + dim + '-format ' + file_format + ' -o ' + temp_mesh_file + '' + options
FreeCAD.Console.PrintMessage("Running: {}".format(command))
try:
output = subprocess.check_output([command, '-1'], shell=True, stderr=subprocess.STDOUT,)
output = subprocess.check_output(command, shell=True, stderr=subprocess.STDOUT,)
else:
FreeCAD.Console.PrintMessage(output)
if file_format in ('unv', 'med'):
Fem.insert(temp_mesh_file, FreeCAD.ActiveDocument.Name)
if file_format == 'stl':
Mesh.insert(temp_mesh_file, FreeCAD.ActiveDocument.Name)
if self.cb_mec_anal.isChecked():
FMesh = App.activeDocument().ActiveObject
FemAnalysis.makeFemAnalysis('MechanicalAnalysis')
FemGui.setActiveAnalysis(App.activeDocument().ActiveObject)
App.activeDocument().ActiveObject.Member = App.activeDocument().ActiveObject.Member + [FMesh]
FMeshG = Gui.ActiveDocument.ActiveObject
FMeshG.DisplayMode = "Elements & Nodes"
except:
FreeCAD.Console.PrintError("Unexpected error in GMSHMesh macro: {}".format(sys.exc_info()[0]))
finally:
try:
del temp_file
except:
pass
try:
del temp_mesh_file
except:
pass
mw = FreeCADGui.getMainWindow()
d = QtGui.QDockWidget()
d.setWidget(MeshGmsh())
d.toggleViewAction().setText("Gmsh")
d.setAttribute(QtCore.Qt.WA_DeleteOnClose)
d.setWindowTitle(" GMSH Mesh Generator ")
mw.addDockWidget(QtCore. Qt.RightDockWidgetArea, d)
# END OF MACRO
