appimage
Re: appimage
I don't have time to do any test ATM. But @Kunda1 do you have default (application) web browser set in your environment? On Ubuntu (GNOME) it is easy to change/set one.
http://askubuntu.com/questions/79305/ho ... lt-browser
Here is the documentation for Arch:
https://wiki.archlinux.org/index.php/de ... plications
And it says such setting depends on the desktop environment used. Therefore i am guessing you likely don't have it set. I found some reference:
http://unix.stackexchange.com/questions ... on-manjaro
Re: appimage
triplus wrote:I don't have time to do any test ATM. But @Kunda1 do you have default (application) web browser set in your environment?
ghee@beast ~]$ xdg-settings get default-web-browser
firefox.desktop
Re: appimage
Follow up to the web browser issue. I ran Appimage from the console and the output I got recreating the issue was:
Reading up on this at https://forum.manjaro.org/t/firefox-kde ... ul-so/4510 seems like a Manjaro/FF issue. Will report once I remove FF, restart, and re-install.
Edit: Confirmed that changing the default browser to Chrome fixed the issue. But I'm getting very slow loading times and it's not my inet connection.
XPCOMGlueLoad error for file /usr/lib/firefox/libxul.so:
/usr/lib/firefox/libxul.so: undefined symbol: sqlite3_expanded_sql
Couldn't load XPCOM.
Re: appimage
Hi Kunda1.
Thanks for confirming. Reinstalling Firefox didn't fix the problem for Firefox?
P.S. If this is related to some bug on certain Linux distribution i am not exactly sure on how much sense does it make to investigate it from AppImage point of view.
Re: appimage
Hi @probono.
External dependency matplotlib can't be imported successfully. If python-matplotlib package is installed i can import matplotlib:
Successfully from FreeCAD Python console. But trying to do the same in FreeCAD packed as AppImage it doesn't work. Any chance this could be fixed easily or python-matplotlib package would need to be added in AppImage? That would likely add to the size of AppImage substantially.
import matplotlib
Re: appimage
import sys
sys.path.append("/usr/lib/pymodules/python2.7/")
import matplotlib
OS: Ubuntu 14.04.5 LTS
Version: 0.17.11174 (Git)
Build type: None
Hash: 0e9c1c076e311f2c3903cfa9de87c8c88daa79de
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Native System kubuntu 14.04
"fight the good fight"
Re: appimage
To whomever builds appimages. I'm very grateful for this, as it greatly simplifies testing new stuff. One minor suggestion would be including IfcOpenShell into the build for opening/saving IFC files. Currently it doesn't seem to be there and it doesn't see the library even if it's installed to /usr. Thanks!
Re: appimage
Hi @prokoudine.
Likely we won't be adding more external software/libraries to AppImages any time soon. Can you test the suggestion by @sgrogan (by changing/adding the path to IfcOpenShell location)? To see if such solution applies to IfcOpenShell and you can import the library in FreeCAD after successfully.
P.S. Would do the tests myself but i don't have IfcOpenShell installed ATM.
Re: appimage
I know this works on Ubuntu 14.04 (I have a macro on my system that does this) from memory I think the path to a self compiled/installed ifcopenshell was
/usr/lib/python2.7/dist-packages/
Re: appimage
Creating symlink in such way would likely only work for Python module where everything is contained in a single file. As if import of some external module would be included in it. That likely wouldn't work.
