Suggestions for a Separate Structure Workbench
I am, a programmer and working with my friend Nirbhay Chauhan(cnirbhay) from structural engineering. We are with an idea to develop a new separate workbench for structural engineering.
There are many difficulties we are facing in the current Arch workbench, like the rebaring process is quite lengthy and doesn't fulfill the required needs. One has to draw the reinforcement map by providing constraints w.r.t. the axis and/or origin in the sketcher workbench. Our requirement is to provide the cover and other such parameters w.r.t. the structural component. The new workbench should contain enough of parameters to easily model the reinforcements. The parameters may be like spacing, diameter, clear cover and effective cover which should be given by the user prior to modeling rather than creating the sketch first.
Therefore, I request all the experts of this forum to kindly guide us in the above mentioned issue.
I'll be very thankful to all of you.
Amritpal Singh
http://www.amritpals.com
https://github.com/amrit3701
Amritpal Singh
Re: Suggestions for a Separate Structure Workbench
There are already a lot of things going on regardin g the implementation of structure tools in FreeCAD. Check for ex:
- The flamingo tools addon https://github.com/oddtopus/flamingo
- This viewtopic.php?f=23&t=17453&p=137525#p137525 or this viewtopic.php?f=23&t=16375 or any other post by chakkree memberlist.php?mode=viewprofile&u=6331
- The arch precast tools viewtopic.php?f=9&t=16155
- Plus all the integration with FEM that Bernd and others are working on...
There are many people with many ideas about the subject out there, what is mostly needed would be to synthetize all these ideas, see what is done and what is missing, and develop a good plan...
+1yorik wrote:There are many people with many ideas about the subject out there, what is mostly needed would be to synthetize all these ideas, see what is done and what is missing, and develop a good plan...
For sure it can be more then just rebar...
Wow, I'm curious ! Check this thread viewtopic.php?f=18&t=17061
Greetings,
Thanks for suggesting about Flamingo workbench but I want to create members (column, beam and slab etc) having rebars of different shape with some default values of different parameters like a clear cover, edge cover etc. In the whole process, I want to automate all user stuff. However, you gave me a solution of Flamingo workbench but this workbench is totally different from my requirements.
I have created some python programs which automate the work. Now my question is what method or procedure will I have to follow if I want a user to run those program from FreeCAD GUI and a user will update those parameter values from "property value" table? My job is similar like when we creates the structural objects, there are some precast concrete elements already present which will automate user work.
Amritpal Singh
Amritpal Singh
To have objects that store parameter values, that the user can modify in the properties panel, you need to create parametric objects. Refer to http://www.freecadweb.org/wiki/index.ph ... ed_objects
To be able to launch scripts from the FreeCAD GUI, there are several ways to do that, from simple to complex. You could simply store your scripts as macros, and the user can launch them from the Macros menu (or even create toolbar buttons from them via Tools -> Customize). But if your colleciton of scripts becomes consequent, it might be best to turn them into a workbench. A workbench is nothing else that a folder containing an Init.py and/or InitGui.py. Then you need to define FreeCAD commands, that can be made into menuitems or toolbar buttons. Check on https://github.com/FreeCAD/FreeCAD-addons for many examples.
@Amrit, We need to work more on this and need to speed up the things a bit. Thanks, @Yorik for the help as always.amrit3701 wrote:Greetings,
Yeah, making programs using parametric objects is a very good thing because it will solve my half problem.yorik wrote:To have objects that store parameter values, that the user can modify in the properties panel, you need to create parametric objects. Refer to http://www.freecadweb.org/wiki/index.ph ... ed_objects
Yes, according to my requirements I also think that creating a separate workbench is a good choice for me. Can you share any documentation and tutorial which will helpful while creating a workbench?To be able to launch scripts from the FreeCAD GUI, there are several ways to do that, from simple to complex. You could simply store your scripts as macros, and the user can launch them from the Macros menu (or even create toolbar buttons from them via Tools -> Customize). But if your colleciton of scripts becomes consequent, it might be best to turn them into a workbench. A workbench is nothing else that a folder containing an Init.py and/or InitGui.py. Then you need to define FreeCAD commands, that can be made into menuitems or toolbar buttons. Check on https://github.com/FreeCAD/FreeCAD-addons for many examples.
I will give my all the updates here.
Thanking you,
Amritpal Singh
Hi Yorik,amrit3701 wrote:I will give my all the updates here.
I read both the links which you have shared and from those links I understood that the FreeCAD objects are separated into App and GUI parts. The app part, the Document Object, defines the geometry of our object (stores values of different parameters of an object), while its GUI part, the View Provider Object, defines how the object will be drawn on a screen.
I have gone through all the examples present in "src/Mod/TemplatePyMod/FeaturePython.py" but I unable to understand the code of ViewProviderBox class. How all the things actually works in FreeCAD? And also, Is there any difference present between "App::FeaturePython" and "Part::FeaturePython"?
Amritpal Singh
That's a much too large question, I don't know how to answer that!amrit3701 wrote:How all the things actually works in FreeCAD?
The App::FeaturePython is based on the simple generic App::Feature. It basically does nothing. You need to do everything yourself in the python code.amrit3701 wrote:Is there any difference present between "App::FeaturePython" and "Part::FeaturePython"?
The Part::FeaturePython is based on Part::Feature which already does a lot of things: It already comes with several defined properties such as Placement and Shape, and if you give it a shape, it will compute a coin3d representation of it automatically. In Draft.py, for example, both are used. Most Draft objects, that are based on shapes, use Part::Feature. But some others, the dimension for example, doesn't have a shape, and is therefore an App::FeaturePython.
