surface flattening
Site Admin
Re: surface flattening
Postby wmayer » Sun Nov 05, 2017 2:52 pm
Which Eigen3 version do you use? Mine is 3.2.5 and this lacks of Eigen::LeastSquaresConjugateGradient.
Inside std::function<double(double)> get_basis(int degree, int i, Eigen::VectorXd knots) you use the keyword and. Not sure if the C++ standard defines it, at least MSVC doesn't support it, use && instead. The same is with not, use ! instead. And the same with or, use || instead.
The Cmake file should be changed to:
################################ flat mesh ###############################
SET(FLATMESH_SRCS
    MeshFlattening.cpp
    MeshFlattening.h
    MeshFlatteningNurbs.h
    MeshFlatteningNurbs.cpp
    MeshFlatteningLscmRelax.h
    MeshFlatteningLscmRelax.cpp
if (PYBIND11_FOUND)
SET(FLATMESH_SRCS
    ${FLATMESH_SRCS}
    MeshFlatteningPy.cpp
endif()
add_library(flatmesh SHARED ${FLATMESH_SRCS})
SET_PYTHON_PREFIX_SUFFIX(flatmesh)
target_link_libraries(flatmesh ${PYTHON_LIBRARIES} ${MeshPart_LIBS})
SET_BIN_DIR(flatmesh flatmesh /Mod/MeshPart)
install(TARGETS flatmesh DESTINATION ${CMAKE_INSTALL_LIBDIR})
looo
Postby looo » Sun Nov 05, 2017 8:43 pm
wmayer wrote:Which Eigen3 version do you use? Mine is 3.2.5 and this lacks of Eigen::LeastSquaresConjugateGradient.
thanks for havin a look at this. eigen is version 3.3.3 from conda-forge. Conda is quite fast with adding new versions...
wmayer wrote:Inside std::function<double(double)> get_basis(int degree, int i, Eigen::VectorXd knots) you use the keyword and. Not sure if the C++ standard defines it, at least MSVC doesn't support it, use && instead. The same is with not, use ! instead. And the same with or, use || instead.
This should be corrected. With your suggestion for cmake the library should be build also without pybind11. But there are still these occ-errors...
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
Site Admin
Postby wmayer » Sun Nov 05, 2017 9:37 pm
I don't get them.
looo
Postby looo » Mon Nov 06, 2017 5:32 pm
wmayer wrote:I don't get them.
which occ-version are you using?
Site Admin
Postby wmayer » Mon Nov 06, 2017 6:52 pm
OS: Windows 7
Version: 0.17.12559 (Git)
Hash: 41deaf82dd52c9f5aa48302f2c4d30a481ba7292
Python version: 2.7.8
OCC version: 7.0.0
Site Admin
Postby wmayer » Mon Nov 06, 2017 9:05 pm
These are all the changes I made to build the sources:
diff --git a/src/Mod/MeshPart/App/MeshFlattening.cpp b/src/Mod/MeshPart/App/MeshFlattening.cpp
index a4fcb6f..ba057b7 100644
--- a/src/Mod/MeshPart/App/MeshFlattening.cpp
+++ b/src/Mod/MeshPart/App/MeshFlattening.cpp
@@ -21,6 +21,7 @@
+#include "PreCompiled.h"
 #include "MeshFlattening.h"
 #include "MeshFlatteningLscmRelax.h"
 #include <Poly_Triangulation.hxx>
diff --git a/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.cpp b/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.cpp
index 42b8cd7..f46d563 100644
--- a/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.cpp
+++ b/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.cpp
@@ -20,10 +20,10 @@
 #include <Eigen/IterativeLinearSolvers>
-#include<Eigen/SparseCholesky>
+#include <Eigen/SparseCholesky>
 #include <Eigen/SVD>
 #include <iostream>
 #include <algorithm>
diff --git a/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.h b/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.h
index c6bcccf..8147b39 100644
--- a/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.h
+++ b/src/Mod/MeshPart/App/MeshFlatteningLscmRelax.h
@@ -43,6 +43,7 @@
+#include "MeshFlattening.h"
 typedef Eigen::SparseMatrix<double> spMat;
@@ -50,12 +51,6 @@ typedef Eigen::SparseMatrix<double> spMat;
 typedef Eigen::Vector3d Vector3;
 typedef Eigen::Vector2d Vector2;
-template <typename type, unsigned int size>
-using ColMat = Eigen::Matrix<type, Eigen::Dynamic, size>;
-using RowMat = Eigen::Matrix<type, size, Eigen::Dynamic>;
 class LscmRelax{
 private:
     ColMat<double, 3> q_l_g;  // the position of the 3d triangles at there locale coord sys
diff --git a/src/Mod/MeshPart/App/MeshFlatteningNurbs.cpp b/src/Mod/MeshPart/App/MeshFlatteningNurbs.cpp
index 63eb540..bc7fa28 100644
--- a/src/Mod/MeshPart/App/MeshFlatteningNurbs.cpp
+++ b/src/Mod/MeshPart/App/MeshFlatteningNurbs.cpp
@@ -21,6 +21,7 @@
 #include "MeshFlatteningNurbs.h"
 #include <iostream>
 #include "math.h"
diff --git a/src/Mod/MeshPart/App/PreCompiled.h b/src/Mod/MeshPart/App/PreCompiled.h
index e7463d3..9d02c81 100644
--- a/src/Mod/MeshPart/App/PreCompiled.h
+++ b/src/Mod/MeshPart/App/PreCompiled.h
@@ -38,6 +38,7 @@
 #endif
 #ifdef _MSC_VER
+# pragma warning(disable : 4244)
 # pragma warning(disable : 4275)
 # pragma warning(disable : 4290)
 #endif
looo
Postby looo » Mon Nov 06, 2017 9:44 pm
thanks, now this looks better. I guess the missing PreCompiled.h where the source of the occ error?
but with pybind11 there is still a problem, but I think this is related to something else...
MeshFlatteningPy.cpp.obj : error LNK2019: unresolved external symbol __imp_strdup referenced in function "protected: void __cdecl pybind11::cpp_function::initialize_generic(struct pybind11::detail::function_record *,char const *,class type_info const * const *,unsigned __int64)" (?initialize_generic@cpp_function@pybind11@@IEAAXPEAUfunction_record@detail@2@PEBDPEBQEBVtype_info@@_K@Z)
Site Admin
Postby wmayer » Wed Nov 08, 2017 9:19 am
IIRC to use pybind11 on Windows you must use VS 2015 but this is currently not an option at all as I think you also need at least Windows 8.
looo
Postby looo » Wed Nov 08, 2017 9:33 am
I am using vs2015 with conda, and I think this should also be possible with win7, at least the packages I use are compiled with vs15 on windows 7... But I also think this is somehow related to pybind11.
