surface flattening
looo
Re: surface flattening
Postby looo » Wed Nov 08, 2017 9:25 pm
I already thought about changing to pycxx, but I don't think it's easy to connect numpy arrays to eigen arrays and the other way round. In my eyes this is a missing feature of freecad. Using some established vector-libraries (on both sides) does simplify quite a bit...
please help with my conda-packaging efforts: https://liberapay.com/looooo/
looo
Postby looo » Thu Nov 23, 2017 7:11 pm
I can't reproduce my own reported problem... Now there are only these occ-problems reported. The first looks like this:
C:\Users\fc_builder\Miniconda3\envs\fc_debug\_b_env\Library\include\opencascade\Standard_DimensionError.hxx(26): error C2550: 'Handle_Standard_DimensionError': constructor initializer lists are only allowed on constructor definitions
Does this mean this is an error with occ? I have no clue what it means.
Site Admin
Postby wmayer » Thu Nov 23, 2017 7:14 pm
Can you post the content of Standard_DimensionError.hxx?
looo
Postby looo » Thu Nov 23, 2017 7:59 pm
// Created on: 1991-09-05
// Created by: J.P. TIRAUlt
// Copyright (c) 1991-1999 Matra Datavision
// Copyright (c) 1999-2014 OPEN CASCADE SAS
// This file is part of Open CASCADE Technology software library.
// This library is free software; you can redistribute it and/or modify it under
// the terms of the GNU Lesser General Public License version 2.1 as published
// by the Free Software Foundation, with special exception defined in the file
// OCCT_LGPL_EXCEPTION.txt. Consult the file LICENSE_LGPL_21.txt included in OCCT
// distribution for complete text of the license and disclaimer of any warranty.
// Alternatively, this file may be used under the terms of Open CASCADE
// commercial license or contractual agreement.
#ifndef _Standard_DimensionError_HeaderFile
#define _Standard_DimensionError_HeaderFile
#include <Standard_Type.hxx>
#include <Standard_DefineException.hxx>
#include <Standard_SStream.hxx>
#include <Standard_DomainError.hxx>
class Standard_DimensionError;
DEFINE_STANDARD_HANDLE(Standard_DimensionError, Standard_DomainError)
#if !defined No_Exception && !defined No_Standard_DimensionError
  #define Standard_DimensionError_Raise_if(CONDITION, MESSAGE) \
  if (CONDITION) throw Standard_DimensionError(MESSAGE);
#else
#endif
DEFINE_STANDARD_EXCEPTION(Standard_DimensionError, Standard_DomainError)
#endif // _Standard_DimensionError_HeaderFile
Site Admin
Postby wmayer » Fri Nov 24, 2017 8:22 am
OK, and now can you figure out how the macro DEFINE_STANDARD_HANDLE is defined.
looo
Postby looo » Fri Nov 24, 2017 8:53 am
//! For compatibility with previous versions of OCCT, define Handle_Class alias for opencascade::handle<Class>.
#if (defined(_MSC_VER) && _MSC_VER >= 1800)
//! For Visual Studio 2013+, define Handle_Class as non-template class to allow exporting this type in C++/CLI.
#define DEFINE_STANDARD_HANDLECLASS(C1,C2,BC) class C1; class Handle_##C1 : public Handle(C1) \
public: \
  Handle_##C1() {} \
  Handle_##C1(Handle(C1)&& theHandle) : Handle(C1)(theHandle) {} \
  template <class T2, typename = typename std::enable_if <std::is_base_of <C1,T2>::value>::type> \
  inline Handle_##C1(const opencascade::handle<T2>& theOther) : Handle(C1)(theOther) {} \
  inline Handle_##C1(const T2* theOther) : Handle(C1)(theOther) {} \
  template<typename T> inline Handle_##C1& operator=(T theOther) { Handle(C1)::operator=(theOther); return *this; } \
#else
//! For other compilers, use simple typedef
#define DEFINE_STANDARD_HANDLECLASS(C1,C2,BC) class C1; typedef Handle(C1) Handle_##C1;
#endif
#define DEFINE_STANDARD_HANDLE(C1,C2) DEFINE_STANDARD_HANDLECLASS(C1,C2,Standard_Transient)
#define DEFINE_STANDARD_PHANDLE(C1,C2) DEFINE_STANDARD_HANDLECLASS(C1,C2,Standard_Persistent)
I use Handle in 3 places:
const Handle(Poly_Triangulation) &triangulation = BRep_Tool::Triangulation(face, location);
const Handle(Geom_Surface) &_surface = BRep_Tool::Surface(face);
const Handle(Geom_BSplineSurface) &_bspline = Handle(Geom_BSplineSurface)::DownCast(_surface);
looo
Postby looo » Fri Nov 24, 2017 9:52 am
stupid me. It was related to the double declaration of ColMat and RowMat which you allready mentioned some posts ago.
Somehow I haven't saved stuff the last time I worked on this. Now I am getting the allready reported problem:
   Creating library src\Mod\MeshPart\App\flatmesh.lib and object src\Mod\MeshPart\App\flatmesh.exp
MeshFlatteningPy.cpp.obj : error LNK2019: unresolved external symbol __imp_strdup referenced in function "protected: void __cdecl pybind11::cpp_function::initialize_generic(struct pybind11::detail::function_record *,char const *,class type_info const * const *,unsigned __int64)" (?initialize_generic@cpp_function@pybind11@@IEAAXPEAUfunction_record@detail@2@PEBDPEBQEBVtype_info@@_K@Z)
Mod\MeshPart\flatmesh.pyd : fatal error LNK1120: 1 unresolved externals
LINK failed. with 1120
Site Admin
Postby wmayer » Fri Nov 24, 2017 11:14 am
In several places you write opencascade::handle<...>. Don't do this and instead write Handle(...) because otherwise your code doesn't work with older occ versions. Not sure if this is why the build also fails.
looo
Postby looo » Sun Nov 26, 2017 2:57 pm
still the same problem.
Maybe this is related to my windows. No idea how to update my visualstudio libraries.
looo
Postby looo » Mon Dec 04, 2017 5:49 pm
When I tried to compile the current master branch of FreeCAD with pybind11 on windows I get the same error. So this problem is related to the combination freecad-win-pybind11. But as I have too many other tasks right now, I simple wait for next pybind11 release on conda...
