"Solid" clipping plane
looo
Re: "Solid" clipping plane
Postby looo » Fri Apr 21, 2017 2:23 pm
again some references:
coin adds the clipPlane here:
https://github.com/looooo/coin3d/blob/m ... p#L131L144
the plane gets removed when this function is called:
https://github.com/looooo/coin3d/blob/m ... pp#L87L100
The easiest way to implement the caping is to:
1. copy SoClipPlane.h, SoClipPlaneElement.h, SoGLClipPlaneElement.h and the coresponding cpp files.
2. rename Clip to Cap
3. add the gl-stuff for rendering the the cap to SoGLClipPlaneElement::addToElt
Maybe it would be also possible to implement by SubClassing a SoSeparator. But there is the need to get the traversal-end event (pop) and I have no idea how to get this end-event...
looo
Postby looo » Sat Apr 22, 2017 6:58 am
using a SoCallback works also in FreeCAD: (still only python code + some changes in pivy to make the SoCallback work with freecad)
but selection makes some problems...
Is there a way to disable the selection for some renderBelowPath calls?
pablogil
Postby pablogil » Sat Apr 22, 2017 8:47 am
Very interesting! It's almost done
Cheers
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
looo
Postby looo » Sat Apr 22, 2017 9:33 pm
Yes, after playing with the stencil-buffer another time, the problem with the selection is gone.
Currently the algorithm has some problems with the sketcher (crash) and there are still some small artifacts with lines... Also I do not know how to draw the capping-plane. Somehow the size has to be specified.
import sys
from PySide import QtGui
from pivy import coin
from OpenGL.GL import *
handled=False
class CapPlane():
    def __init__(self, node):
        self.node = node
    def stencilBuffer(self, action):
        glEnable(GL_CLIP_PLANE0)
        glEnable(GL_STENCIL_TEST);
        glClear(GL_STENCIL_BUFFER_BIT);
        glEnable(GL_DEPTH_TEST);
        glEnable(GL_CULL_FACE)
        glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
        # Draw Front faces and decrease stencil-buffer
        # where the front_face is drawn
        glStencilFunc(GL_ALWAYS, 0, 0);
        glDisable(GL_DEPTH_TEST)
        glStencilOp(GL_KEEP, GL_KEEP, GL_INVERT)
        glCullFace(GL_FRONT)
        self.node.GLRenderBelowPath(action)
        # draw the back_face to the stencil-buffer
        # decrease the stencil buffer where the back-face is drawn
        glCullFace(GL_BACK)
        # Draw a quad aligned with the stencil plane,
        # but set the stencil test to reject pixels unless the stencil is set.
        glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE)
        glDisable(GL_CLIP_PLANE0)
        glStencilFunc(GL_NOTEQUAL, 2, ~0)
        glStencilFunc(GL_NOTEQUAL, 0, ~0)
        glColor3f(0.8, 0.8, 0.8)
        glDisable(GL_CULL_FACE)
        glDisable(GL_LIGHTING)
        glBegin(GL_QUADS)
        glVertex3fv([-10000,-10000, 3])
        glVertex3fv([ 10000,-10000, 3])
        glVertex3fv([ 10000, 10000, 3])
        glVertex3fv([-10000, 10000, 3])
        glEnd()
        glEnable(GL_LIGHTING)
        glDisable(GL_STENCIL_TEST)
def myCallbackRoutine(cap, action):
    global handled
    if not action.isOfType(coin.SoGLRenderAction.getClassTypeId()):
        return
    if not handled:
        handled = True
        cap.stencilBuffer(coin.SoGLRenderAction.constructFromAction(action))
        handled = False
view = Gui.ActiveDocument.ActiveView
sg = view.getSceneGraph()
myCallback = coin.SoCallback()
cap = CapPlane(sg)
myCallback.setCallback(myCallbackRoutine, cap)
plane = coin.SbPlane(coin.SbVec3f(0,0,1), coin.SbVec3f(0,0,3))
clip = coin.SoClipPlane()
clip.plane = plane
sg.insertChild(clip, 2)
sg.insertChild(myCallback, 3)
HoWil
Postby HoWil » Sun Apr 23, 2017 9:20 am
Looks nice,
Is this possible without blocking the Task-panel as the original clipping tool does?
This could be very usefull for FEM-wb for selecting inner solids and faces.
Please see also https://forum.freecadweb.org/viewtopic. ... 50#p151950 to get an impression what I need sometimes in FEM-wb.
BR,
HoWil
looo
Postby looo » Sun Apr 23, 2017 10:21 am
HoWill wrote:Is this possible without blocking the Task-panel as the original clipping tool does?
Maybe the SoClipPlanManip node could be useful. I think drawing the cap is not that important for this task.
sg = Gui.ActiveDocument.ActiveView.getSceneGraph()
clip_plane = coin.SoClipPlaneManip()
sg.insertChild(clip_plane, 0)
# sg.removeChild(clip_plane, 0)
yorik
Site Admin
Postby yorik » Sun Apr 23, 2017 6:33 pm
very interesting progresses looo! Didn't think there was something liek that available at coin level already...
looo
Postby looo » Mon Apr 24, 2017 3:57 pm
yorik wrote:very interesting progresses looo! Didn't think there was something liek that available at coin level already...
it isn't yet available with coin. My code implement the capping at opengl-level. But it is very nice that this is possible from python...
I have done some further tests, but didn't find a way to remove the artifacts... I think this isn't a problem of the stencil-buffer algorithm. But maybe there is a way to get rid of the artifacts (use the shaded render mode for the stencil renderings)
I also had a look how the clipping-plane is implemented in osg. And I think there approach (every separator can enable a clipping-plane) is more suited for CAD.
Does FreeCAD already use a subclass of a SoSeparator for shapes? If not I would suggest to do so and implement the "CAD-clipping" at the separator-level. The idea is to have clipping planes defined in a separator somewhere near the root-separator and CAD-Separators to implement the glEnable(GL_CLIP_PLANE0) and glDisable(GL_CLIP_PLANE0)...
The CAD-Sparator then gets two bool-value for the clip-type shell/solid, on/off. In SoSeparator::GLRenderInPath the planes get enabled and regarding the clip-style the stencil-buffer-algorythm will be used or not.
In SoSeparator::GLRenderOffPath the plane gets disabled. Maybe a SoAction can be used to enable/disable the clip-planes for all separator.
questions:
1: If I implement this in FreeCAD, is it possible to have this SoSeparator-subclass available from python, and use it like a pivy-node?
2: Can I switch the rendermode for the two stencil-buffer-renderings? And how to achieve that? (It seems the rendermode with only polygons, doesn't show any artifacts.)
Site Admin
Postby wmayer » Mon Apr 24, 2017 5:25 pm
type=coin.SoType.fromName("SoFCSelection") # FreeCAD specific type
type.isBad() # => 0, i.e. OK
node=type.createInstance()
looo
Postby looo » Tue Apr 25, 2017 7:48 am
thanks, this is perfect.
Tested the python code posted above in windows, and there no artifacts are visible... but somehow the line picking is affected.
