Use case
jriegel
Site Admin
Use case
Postby jriegel » Tue Nov 08, 2011 9:41 pm
Since we do a Open Source CAD I think this might be good use case for dog-fooding:
http://reprap.org/wiki/Prusa#Printed_Parts
Stop whining - start coding!
carlod
Re: Use case
Postby carlod » Thu Nov 10, 2011 9:32 am
I can use it for some testing.. :)
Here the first part on the list.
The dimensions aren't exact because I haven't solidworks so I open the STL in freecad and copy it
And here my first issue:
If you look inside the part, the two pocket features create a not needed additional face (like a triangle).
I cannot upload images on the forum.
More model will came.
coupling.FCStd
(64.94 KiB) Downloaded 106 times
carlod
Re: Use case
Postby carlod » Thu Nov 10, 2011 9:48 am
Number 2
I think this project can be used to test what is being done with the assembly module project
endstop-holder.FCStd
(63.39 KiB) Downloaded 105 times
jriegel
Site Admin
Re: Use case
Postby jriegel » Thu Nov 10, 2011 1:30 pm
Cool!
Please report if you got some problems to design a part!
Exactly that was my idea. It has some parts we have to design and it has some standard/catalog parts. Put that
all together with Assembly will give a formidable test! And the best of it - its a open source project!!
carlod
Re: Use case
Postby carlod » Thu Nov 10, 2011 3:01 pm
Number 6
that was not really easy. :D
Not very well copy because it is a strange part and some dimensions here is really needed..
I've jumped 3 parts because are more complex and I'm stuck with some problems of freecad.
When I have more time I will go deep for these. ;)
One word.
I've used the equality constrain to sketch the heptagon. Really easy :D
Sometimes during my work I use catia but now I'm a freecad user. When sketching in catia I noticed (but maybe Im wrong) that this constrain isn't implementend but I've learned that is really usefull. :o
So +1 for freecad!!
y-motor-bracket.FCStd
(124.56 KiB) Downloaded 101 times
NormandC
Re: Use case
Postby NormandC » Thu Nov 10, 2011 3:14 pm
Hey carlod,
Leave some for others! ;)
There's another topic about a Mendel part here (the frame-vertex part): viewtopic.php?f=3&t=1873
P.S. I think this part is for the original Mendel, not the Prusa...
tanderson69
Re: Use case
Postby tanderson69 » Thu Nov 10, 2011 4:41 pm
carlod wrote: And here my first issue:
this is a common result with the opencascade modeling kernel and coincident faces. It is weird for me also as parasolid will detect these "equivalent" faces and make them one. If you take a couple of boxes and unite them (attachment) you will see the same kind of result. There is more than one boolean unite command inside opencascade and the two that I tried with OCE and DRAWEXE didn't help this situation. I thought about submitting this to OCE as a request, but I haven't.
boxUnit.png.zip
not a zip
(111.06 KiB) Downloaded 104 times
jriegel
Site Admin
Re: Use case
Postby jriegel » Thu Nov 10, 2011 4:56 pm
Yes this is a known problem. There was a old boolean lib in CasCade which did not have that problem but had other issues...
If FreeCAD gets wider usage maybe some time someone shows up with the skill and will to fix such stuff...
kwahooo
Re: Use case
Postby kwahooo » Thu Nov 10, 2011 6:07 pm
I created (succesful!) Pad001 with negative value (it was needed to change direction). However i got a message:
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: value must be nonnegative
x-end-motor.fcstd
(42 KiB) Downloaded 56 times
kwahooo
Re: Use case
Postby kwahooo » Thu Nov 10, 2011 9:50 pm
And, finally I also made something:)
File: http://ubuntuone.com/7Ab26Yg8G78FoNOad0wTvW
