Subdivision To N.U.R.B.S. (IGES) for free
pafurijaz
Postby pafurijaz » Sun Dec 18, 2016 6:26 pm
Hi all, I have a little trick that I discovered just today and wanted to share it with you.
I found an easy way to convert the subdivision surfaces, in to nurbs surfaces.
To do this you need two free programs ' FreeShip_Plus ' and another to convert VRML format ' 1 '
First you need to export your files from Blender, eliminating the subdivision modifier and export to obj with the Z axis at the top, after using the program "meshconv" to convert from obj to wrl.
Open ' FreeShip ' and import the VRML format 1 of your object and go to export in IGES and you're done you'll have the nurbs surfaces generated from the cage of your mesh object.
Then import your IGES file with FreeCad and export it in STEP to others CAD
Object converter
http://www.patrickmin.com/meshconv/
Usage: meshconv -c wrl -vrmlver 1 blender-file.obj
Free!Ship Plus
https://github.com/markmal/freeship-plu ... s/releases
Thread on blenderartist.org (With images)
https://blenderartists.org/forum/showth ... )-for-free
I also think it would be possible to use the Freeship's method of exporting to IGES, to convert the mesh, in to nurbs surfaces, internally to FreeCad. Of course I simplify, because here need someone who programs all that, but you could get ideas!
microelly2
Re: Subdivision To N.U.R.B.S. (IGES) for free
Postby microelly2 » Mon Dec 19, 2016 9:00 am
The problem of the mesh formats: They are triangulated and loose the fine power of nurbs representation.
So the output becomes complex and overloaded.
pafurijaz
Postby pafurijaz » Mon Dec 19, 2016 10:27 am
Hi, definitely for complex objects and with too many triangles you cannot expect good results, but for items with a good topology you can get excellent results in a very short time, exported a variety of surfaces short time.
Freeship saves files instantly and I think with an script in freeCad, you may have acceptable results.
Surface from Blender
Schermata del 2016-12-19 11-13-59.png (58.99 KiB) Viewed 4084 times
boat made in Blender
Schermata del 2016-12-19 11-20-00.png (37.1 KiB) Viewed 4084 times
Blender View
Schermata del 2016-12-19 11-33-43.png (87.41 KiB) Viewed 4078 times
Sub_surf_j.fcstd
Surface Nurbs
(97.86 KiB) Downloaded 75 times
microelly2
Postby microelly2 » Mon Dec 19, 2016 2:31 pm
Okay I see , thank you for the example,
I will have a look at it in detail.
regis
Postby regis » Tue May 23, 2017 5:28 am
pafurijaz wrote:Hi all, I have a little trick that I discovered just today and wanted to share it with you.
Object converter
Free!Ship Plus
Hello, i've been very interested in your process but unable to recreate, It seems meshconv doesn't seem to work on my computer. Can you show a step by step or a short video clip?
pafurijaz
Postby pafurijaz » Sat Aug 12, 2017 10:22 am
I saw just now, I looked for months but nobody seemed interested until I stopped. :shock: :shock:
pafurijaz
Postby pafurijaz » Sat Aug 12, 2017 10:23 am
A quick tutorial about how to convert.
The steps to convert:
1. Export from Blender in OBJ.
2. Convert from OBJ to VRML1, with Meshconv. **
3. Start FreeShip, and import the VRML1.
4. Export the file to IGES (NURBS).
5. Start FreeCad and then open IGES file and export it, to IGES or other formats NURBS, Moi3d does not open the file exported by FreeShip.
** Meshconv usage: meshconv -c wrl -vrmlver 1 blender-file.obj
Postby Kunda1 » Sat Aug 12, 2017 12:27 pm
This looks useful! Lets document this on the wiki..eh? @pafurijaz would you like to do that ? (I can make you an account if so)
Site Admin
Postby wmayer » Sat Aug 12, 2017 3:31 pm
I was playing a bit with FreeShip but none of the IGES files it created I could load into FreeCAD. Could you please upload some test files, e.g. the obj file of the monkey and the IGES file FreeShip creates?
EDIT:
Btw, you can also create VRML1 files with FreeCAD with a manual change afterwards. Therefore save a mesh (in the Mesh workbench) as OpenInventor and the file extension .iv. Then open the .iv file and change the header from
#Inventor V2.1 ascii
to
#VRML V1.0 ascii
and change the file extension to wrl or vrml
regis
Postby regis » Sun Aug 13, 2017 12:36 pm
EDIT:
to
#VRML V1.0 ascii
Is is possible to import a blender subdivision curve surface and/or nurbs into freecad and have bhem appear as nurbs?
I've been trying to recreate the process mentioned above
no luck with using freeship, Ayam, gcad3d and Meshconv
essentially, how can you make sure your blender model gets translated into curve faces?
