Bug #2774: [Sketcher] Can not select points in sketcher properly when changing viewangle
Postby Kunda1 » Wed Jan 11, 2017 7:16 pm
Can someone please test issue #2774
I can't seem to reproduce it. Thanks!
sgrogan
Re: Bug #2774 Can not select points in sketcher properly when changing viewangle
Postby sgrogan » Wed Jan 11, 2017 7:52 pm
Kunda1 wrote:Can someone please test issue #2774
I can reproduce it, but I think its the intended behavior. In the Top View the points are "over" the line so they can be selected. In the Bottom view the points are "under" the line so the line is selected. I don't have any problems with box selection it works as expected.
Switch to the front view and zoom way in on an endpoint to see.
Joachimthome
Postby Joachimthome » Wed Jan 11, 2017 9:31 pm
Happy that i t could be reproduced.
I really dont know about the intention of this. For me it was very unintuitive when i encountered that issue when i was creating a model where it made just from a practical point of view sense to edit the sketch from below.
I took me around an hour of frustrating testing to find out what the heck was going on before i found the reason of it happening because i first thought the program was broken somehow (because i was always retrying from bottom view).
And it does not make sense because from the top view i have all functions (handling points and lines) and from bottom view i suddenly loose the function to handle the points but can still handle lines. Box selection works but actually handling the point is impossible.
Cant imagine a case where this is useful.
DeepSOIC
Postby DeepSOIC » Wed Jan 11, 2017 10:38 pm
This is due to the way Sketcher was coded, and I would consider that the limitation of the chosen method of prioritizing selection. However, this is occasionally useful - one can select a line that is obscured by other line, by viewing the sketch upside down. But, it's not enough usefulness to justify sticking with what we have, I think it should be fixed some day.
sgrogan
Postby sgrogan » Wed Jan 11, 2017 10:48 pm
DeepSOIC wrote: think it should be fixed some day.
What would the fix be? For a line, sure, ignore the end of the line and always pick the endpoint.
How about over lapping lines? Not valid for padding etc but possible. Also a horizontal or vertical line constrained to the origin. I always resort to the element dialog.
Postby Kunda1 » Thu Jan 19, 2017 12:28 am
Verdict?
sgrogan
Postby sgrogan » Thu Jan 19, 2017 12:34 am
Kunda1 wrote:Verdict?
I defer to DeepSOIC here. Bug or enhancement I don't know.
Postby Kunda1 » Thu Jan 19, 2017 12:41 am
How do you ping DeepSOIC on the forum through a forum message?
sgrogan
Postby sgrogan » Thu Jan 19, 2017 12:46 am
Kunda1 wrote:How do you ping DeepSOIC on the forum through a forum message?
I don't think @DeepSOIC works, but I think he'll see it. Otherwise PM. I'd give it a day.
cox
Postby cox » Thu Jan 19, 2017 1:43 am
I agree with @DeepSOIC. Would be a big user experience improvement. Should be fixed at some point.
One intermediate solution could be to use a hotkey to reverse or flip the "layers" just when you need it. Would be faster and less disorienting than turning the whole model, sometimes looking at the model from the opposite side, is no good when it is obstructed on that side.
