here are some code snippets that may be of interest for you.
To get the main window via PyQt:
from PyQt4 import QtGui
from PyQt4 import QtCore
def getMainWindow():
toplevel = QtGui.qApp.topLevelWidgets()
for i in toplevel:
if i.metaObject().className() == "Gui::MainWindow":
return i
raise Exception("No main window found")
mw=getMainWindow()
def get3dview(mw):
childs=mw.findChildren(QtGui.QMainWindow)
for i in childs:
if i.metaObject().className()=="Gui::View3DInventor":
return i
return None
v=get3dview(mw)
# -*- coding: utf-8 -*-
# Form implementation generated from reading ui file 'mainwindow.ui'
# Created: Sun Dec 27 11:18:56 2009
# by: PyQt4 UI code generator 4.6
# WARNING! All changes made in this file will be lost!
from PyQt4 import QtCore, QtGui
class Ui_MainWindow(object):
def setupUi(self, MainWindow):
MainWindow.setObjectName("MainWindow")
MainWindow.resize(508, 436)
self.centralwidget = QtGui.QWidget(MainWindow)
self.centralwidget.setObjectName("centralwidget")
self.gridLayout = QtGui.QGridLayout(self.centralwidget)
self.gridLayout.setObjectName("gridLayout")
self.mdiArea = QtGui.QMdiArea(self.centralwidget)
self.mdiArea.setViewMode(QtGui.QMdiArea.TabbedView)
self.mdiArea.setTabPosition(QtGui.QTabWidget.South)
self.mdiArea.setObjectName("mdiArea")
self.gridLayout.addWidget(self.mdiArea, 0, 0, 1, 1)
MainWindow.setCentralWidget(self.centralwidget)
self.menubar = QtGui.QMenuBar(MainWindow)
self.menubar.setGeometry(QtCore.QRect(0, 0, 508, 27))
self.menubar.setObjectName("menubar")
MainWindow.setMenuBar(self.menubar)
self.statusbar = QtGui.QStatusBar(MainWindow)
self.statusbar.setObjectName("statusbar")
MainWindow.setStatusBar(self.statusbar)
self.retranslateUi(MainWindow)
QtCore.QMetaObject.connectSlotsByName(MainWindow)
def retranslateUi(self, MainWindow):
MainWindow.setWindowTitle(QtGui.QApplication.translate("MainWindow", "MainWindow", None, QtGui.QApplication.UnicodeUTF8))
ui=Ui_MainWindow()
my_mw=QtGui.QMainWindow()
ui.setupUi(my_mw)
ui.mdiArea.addSubWindow(v)
my_mw.show()
So, I think Jürgen is right that it would be better to create your own 3d view SoQtExaminerViewer or SoQtViewer and "push" the content of FreeCAD's 3d view to your view.
An easy way to get the 3d representation of an object without reimplementing from scratch:
App.activeDocument().addObject("Part::Box","myBox")
s=Gui.activeDocument().getObject("myBox").toString() # store as string
from pivy import coin
inp.setBuffer(s)
node=coin.SoDB.readAll(inp) # restore from string
# add node to the scenegraph of your 3d view
