Civil engineering feature implementation (Transportation Engineering)
Re: Civil engineering feature implementation (Transportation Engineering)
Postby Kunda1 » Tue Sep 10, 2019 6:17 pm
Olé!
ebrahim raeyat
Postby ebrahim raeyat » Thu Sep 12, 2019 1:27 am
Thank @Joel_graff. when i want to activate your workbench this error appeared:
invalid syntax (publisher.py, line 101)
  File "/home/ebi/.FreeCAD/Mod/freecad.trails/freecad/trails/init_gui.py", line 110, in Initialize
    from .project.commands \
  File "/home/ebi/.FreeCAD/Mod/freecad.trails/freecad/trails/project/commands/edit_alignment_cmd.py", line 33, in <module>
    from ..tasks.alignment import edit_alignment_task
  File "/home/ebi/.FreeCAD/Mod/freecad.trails/freecad/trails/project/tasks/alignment/edit_alignment_task.py", line 46, in <module>
    from ...support.publisher import Publisher
it seems it is related to relative import. thanks.
ebrahim raeyat
Postby ebrahim raeyat » Thu Sep 12, 2019 1:29 am
i forgot to mention my freecad system:
OS: Ubuntu 18.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.16718 (Git)
Hash: cfd04ac6afa091f5c4f18e94756bd58fb6d66806
Python version: 3.7.1
Qt version: 5.6.2
Joel_graff
Postby Joel_graff » Thu Sep 12, 2019 2:03 am
I fixed what was breaking it. You'll find that it's not really very useful at this point, however. I'm really just trying to create an initial 0.1 release with the horizontal tool and there's still a lot of bugs to work out.
Still, you can import LandXML with single-center curves and edit it. I suspect it won't save or reload properly anymore - been a long time since I've touched that code and a lot has changed.
There is some test data in the workbench at:
freecad/trails/resources/data/alignment/SugarGroveRoad.xml
ebrahim raeyat
Postby ebrahim raeyat » Thu Sep 12, 2019 7:33 pm
Thanks. it is now working, although i couldn't work with that. nor one open FCStd or import csv or xml.
i will follow your work, it is interesting.
Postby Kunda1 » Thu Sep 12, 2019 8:55 pm
we're on revision 0.19.18198
you should probably update.
Joel_graff
Postby Joel_graff » Thu Sep 12, 2019 9:49 pm
I haven't really been doing a good job making the user interface accessible, I admit.
CSV fucntionality is broken and deprecated. I won't be using it going forward.
You can import an XML file by pressing CTRL_Shift_A. That will let you open a file dialog to pick the XML file. That *should* work. Hakan seemed to make it work on his own LandXML files, anyway.
I really should try to update the commands, though. I've really ignored that stuff because I figured no one was paying attention anyway. ;)
HakanSeven12
Postby HakanSeven12 » Fri Sep 13, 2019 5:26 am
It works except non-infinity spirals :)
Joel_graff
Postby Joel_graff » Fri Sep 13, 2019 11:51 am
Have you had a chance to look at the Geomatics issue yet?
HakanSeven12
Postby HakanSeven12 » Fri Sep 13, 2019 12:01 pm
I dont have enough time for it but you can talk with https://github.com/allilou. Maybe he can do something.
