Civil engineering feature implementation (Transportation Engineering)
Joel_graff
Re: Civil engineering feature implementation (Transportation Engineering)
Post by Joel_graff »
That is pretty neat!
It looks like a spline-based implementation, which is generally useless for traditional transportation engineering design. Microelly and I spent several weeks trying to figure out how to design a spline that reduced to simple curves. I'm sure it's a solvable problem, but not within easy reach at this point.
Joel_graff
HakanSeven12 wrote: Fri Feb 12, 2021 7:04 am
09:56:55  Traceback (most recent call last):
  File "C:\Users\hakan.seven\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\design\alignment\horizontal_alignment.py", line 546, in onChanged
    stations = self.get_stations(vobj.Object)
  File "C:\Users\hakan.seven\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\design\alignment\horizontal_alignment.py", line 601, in get_stations
    tuple_coord, tuple_vec = obj.Proxy.model.get_orthogonal( sta, "Left")
  File "C:\Users\hakan.seven\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\design\alignment\alignment_model.py", line 690, in get_orthogonal
    return _fn[curve.get('Type')].get_ortho_vector(
  File "C:\Users\hakan.seven\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\design\geometry\arc.py", line 812, in get_ortho_vector
    delta = distance / radius
<class 'ZeroDivisionError'>: float division by zero
Some of the alignments dont throw any error but labels looks not aligned.
Can you take a look again? I've imported the alignment, turned on labels, saved it, reloaded it, and it looks ok. The only issue is, if the alignment is saved with the labels turned on, it still reloads with the labels turned off.
I'm not convinced it's ok - I suspect there's something that's not being reloaded properly, but I can't consistently demonstrate a bug to squash.
Anyway, sorry it's taken me so incredibly long to work this out. Work has been getting busy these last few months.
HakanSeven12
Post by HakanSeven12 »
I dont think that a good idea to save and restore model from xml file. So I think my model keeper property working well. Because your solution couse permission errors. But we can use your exporter to export xml files to use with other softwares.
Joel_graff
HakanSeven12 wrote: Fri May 07, 2021 6:46 am I dont think that a good idea to save and restore model from xml file. So I think my model keeper property working well. Because your solution couse permission errors. But we can use your exporter to export xml files to use with other softwares.
That's fine. I was just trying to follow up on this bug - it looks like it's working fine, now?
HakanSeven12
I dont know. I didnt test it and I wont until next monday.
HakanSeven12
It works. The shape of alignments looks normal and create guidelines normally but throw this error. Also its complately not working for d1 kolu.
11:16:32  unable to locate station  0.0 on curve  None
11:16:32  Traceback (most recent call last):
  File "C:\Users\hakan.seven\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\geomatics\guideline\guidelines.py", line 103, in execute
    obj.Shape = self.get_lines(base, alignment, offsets, stations)
  File "C:\Users\hakan.seven\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\geomatics\guideline\gl_func.py", line 78, in get_lines
    tuple_coord, tuple_vec = alignment.Proxy.model.get_orthogonal( sta, "Left")
<class 'TypeError'>: cannot unpack non-iterable NoneType object
jman
Post by jman »
Hi All,
If this is the wrong place to post this sort of question, just let me know and I can remove/post elsewhere.
I am trying to install Trails to be able to import some pretty high-res lidar data. However despite extracting trails and the privy_trackers (and the python support scripts) from github, the Trails module still doesn't seem to want to run, and I get the message below in the report:
20:32:16  non-default argument follows default argument (gl_cluster.py, line 34)
20:32:16  Traceback (most recent call last):
  File "C:\Users\<username>\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\init_gui.py", line 247, in Initialize
    from .geomatics.section import CreateGuideLines
  File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
  File "C:\Users\<username>\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\geomatics\section\__init__.py", line 1, in <module>
    from . import CreateGuideLines
  File "C:\Users\<username>\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\geomatics\section\CreateGuideLines.py", line 28, in <module>
    from . import gl_clusters, gl_cluster
Am I making a stupid mistake here? I appreciate any pointers in advance.
(Running on Windows)
HakanSeven12
Add your system informations please
jman
Post by jman »
See system information below:
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Thanks again.
balrobs
Post by balrobs »
Hi HakanSeven12,
recently I stumbled across a strange FreeCAD behavior ... see following thread:
[Draft] Issue entering point in 3D view
I was wondering if the issue is related to Draft WB or to Trails WB?
Do you have any idea?
Thanks for your valuable help :)
