griffmic88 wrote: ↑Thu May 10, 2018 4:35 pm
This is highly useful to me! I can copy this object into my existing software and since its an object be viewed in a cross section. Since its parametric, even better, I can change it to match my local standards and designs.
Edit: The wingwall angles, and some other features can be modified to fit local standards. A bridge abutment would be an easy one to do I think. I have tried this in Microstation and it works rather well, but it's not perfect (the format can be imported or exported via .CSV as well).
The file is attached.
It's not perfect, and it breaks if you try to adjust the skew in increments greater than 5 degrees. I suspect microelly's animation workbench would be a great way to overcome that...
In the end, you really only have to make a handful of models that vary by number of cells and wingwall types, I think, and you've pretty much covered all of the box culvert use cases. This is a single cell (obviously) with a horizontal wingwall design case.
The other thing I'm trying to do is to hook the model into an external spreadsheet (or even a text file), so that you can modify the parameters outside FreeCAD and see the model update. It seems pretty doable with LibreOffice Calc, and I've got a start on it, but no promises on anything useful in the near future...
