I will look for a method which does not set a constraint value in one step but changes the value of a constraint from the old to the new value wayJoel_graff wrote: ↑Thu May 10, 2018 5:40 pm
It's not perfect, and it breaks if you try to adjust the skew in increments greater than 5 degrees. I suspect microelly's animation workbench would be a great way to overcome that...
on an "secure way".
the simplest way is to run a macro in libre office which saves the data to the file and sends a http request to the FreeCAD webserver.The other thing I'm trying to do is to hook the model into an external spreadsheet (or even a text file), so that you can modify the parameters outside FreeCAD and see the model update. It seems pretty doable with LibreOffice Calc, and I've got a start on it, but no promises on anything useful in the near future...
And than FreeCAD rereads the data.
