Civil engineering feature implementation (Transportation Engineering)
HakanSeven12
Re: Civil engineering feature implementation (Transportation Engineering)
Postby HakanSeven12 » Fri Feb 05, 2021 6:54 am
I made a test for your alignments. I extracted points from alignment for every 10m(in Civil 3D) and I created a FreeCAD file to comperate them. I send point file and FCstd file to you. I think it can be useful for you :)
alignments test.png (114.53 KiB) Viewed 785 times
HakanSeven12
Postby HakanSeven12 » Fri Feb 05, 2021 8:06 am
bernd wrote: Fri Feb 05, 2021 7:48 am
from typing import Final
has been added to pivy trackers
https://github.com/joelgraff/pivy_track ... ums.py#L26
but this is only available for Python 3.8 https://docs.python.org/3/library/typing.html (search for final) and a lot of system do not have Python 3.8 installed (including me on Debian Buster). Would it be possible to make some workaroud for them. Trails does not work ATM.
HakanSeven12
Postby HakanSeven12 » Fri Feb 05, 2021 11:09 am
I added labels to alignment. You can find it under view properties. Default option is False. So you dont see labels until you activate it.
alignment labels.png (115.96 KiB) Viewed 740 times
Joel_graff
Postby Joel_graff » Sat Feb 06, 2021 3:30 pm
Station labels are something I need to add to the design side as well. One more item for the list.
As for the Final thing - I did that to enforce Const-ness for the python coin enumerant classes I created. I can roll that back, though. It's not necessary.
And thanks for the benchmark dataset. If / when I can get around to implementing that indeterminant clothoid, it'll come in handy.
HakanSeven12
Postby HakanSeven12 » Sat Feb 06, 2021 5:12 pm
Joel_graff wrote: Sat Feb 06, 2021 3:30 pm Station labels are something I need to add to the design side as well. One more item for the list.
I added a function to view provider to get stations but you can move it in to alignment model and apply your tuple math codes(I'm not so familiar with that). Also I need a function that return station orthogonal vector angle to rotate label text. So I can make ticks and labels more compatible. Also I want to add labels for horizontal geometry points. So a function that returns that stations can be helpful :)
Joel_graff
Postby Joel_graff » Sat Feb 06, 2021 5:35 pm
HakanSeven12 wrote: Sat Feb 06, 2021 5:12 pm Also I need a function that return station orthogonal vector angle to rotate label text
You can't just use what you use already to calculate section lines?
HakanSeven12 wrote: Sat Feb 06, 2021 5:12 pm Also I want to add labels for horizontal geometry points. So a function that returns that stations can be helpful
That's already done. It may not be ready for public consumption, though.. I'll take a look this week.
HakanSeven12
Postby HakanSeven12 » Sat Feb 06, 2021 6:42 pm
Joel_graff wrote: Sat Feb 06, 2021 5:35 pm You can't just use what you use already to calculate section lines?
That is returning the offset points of stations. How can I get angle from it?
Joel_graff
Postby Joel_graff » Sat Feb 06, 2021 11:27 pm
HakanSeven12 wrote: Sat Feb 06, 2021 6:42 pm That is returning the offset points of stations. How can I get angle from it?
Does this help?
https://github.com/joelgraff/freecad.tr ... el.py#L668
Joel_graff
Postby Joel_graff » Mon Feb 08, 2021 1:18 pm
Joel_graff wrote: Sat Feb 06, 2021 11:27 pm That is returning the offset points of stations. How can I get angle from it?
I didn't see your reply when I posted mine... To get the angle between, I have that built into the TupleMath module in freecad_python_support. I think it's also a function in the FreeCAD.Vector class.
Let me know if you need help sorting that tout, though.
Joel_graff
Postby Joel_graff » Mon Feb 08, 2021 1:21 pm
HakanSeven12 wrote: Sat Feb 06, 2021 5:12 pm So a function that returns that stations can be helpful :)
Are you using the AlignmentModel class? You should be able to get actual stationing from that. Otherwise, I don't think I have a solution - at least, not one that can account for omissions / station equations along the alignment.
