Civil engineering feature implementation (Transportation Engineering)
- HakanSeven12
Re: Civil engineering feature implementation (Transportation Engineering)
I think git assistant can't handle submodule of the submodule. So it can be good to make support the submodule of the trails, not pivy_trackers.
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
I was having the same thoughts - perhaps submodules should only be top-level references, which means they should be at the workbench level only. At very least, it may help eliminate confusion and recursive references.HakanSeven12 wrote: ↑Tue Jun 02, 2020 2:06 pm I think git assistant can't handle submodule of the submodule. So it can be good to make support the submodule of the trails, not pivy_trackers.
I'll see what I can do.
- HakanSeven12
Here my first test for sogeo fpo point group object. What are you thinking about it?
'''Examples for a feature class and its view provider.'''
import FreeCAD, FreeCADGui
from pivy import coin
class PointGroup:
def __init__(self, obj):
'''Add some custom properties to our box feature'''
obj.addProperty("App::PropertyVectorList", "Points", "Base", "List of group points").Points = ()
obj.Proxy = self
self.Points = None
def onChanged(self, fp, prop):
'''Do something when a property has changed'''
FreeCAD.Console.PrintMessage("Change property: " + str(prop) + "\n")
def execute(self, fp):
'''Do something when doing a recomputation, this method is mandatory'''
FreeCAD.Console.PrintMessage("Recompute Python Box feature\n")
class ViewProviderPointGroup:
'''Set this object to the proxy object of the actual view provider'''
obj.addProperty("App::PropertyColor","Color","Box","Color of the box").Color=(1.0,0.0,0.0)
obj.Proxy = self
def attach(self, obj):
'''Setup the scene sub-graph of the view provider, this method is mandatory'''
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
first_node = sg.getChild(1)
node_name = first_node.getClassTypeId().getName()
if node_name == "GeoOrigin":
geo_system = first_node.geoSystem.getValues()
geo_coord = first_node.geoCoords.getValue().getValue()
self.coord = coin.SoGeoCoordinate()
self.coord.geoSystem.setValues(geo_system)
self.coord.point.values = obj.Object.Points
data = coin.SoPointSet()
self.sep = coin.SoGeoSeparator()
self.sep.geoSystem.setValues(geo_system)
self.sep.geoCoords.setValue(geo_coord[0], geo_coord[1], geo_coord[2])
self.shaded = self.sep
self.wireframe = self.sep
self.color = coin.SoBaseColor()
self.shaded.addChild(self.color)
self.shaded.addChild(self.coord)
self.shaded.addChild(data)
obj.addDisplayMode(self.shaded,"Shaded")
style=coin.SoDrawStyle()
style.style = coin.SoDrawStyle.LINES
self.wireframe.addChild(style)
self.wireframe.addChild(self.color)
self.wireframe.addChild(self.coord)
self.wireframe.addChild(data)
obj.addDisplayMode(self.wireframe,"Wireframe")
self.onChanged(obj,"Color")
def updateData(self, fp, prop):
'''If a property of the handled feature has changed we have the chance to handle this here'''
# fp is the handled feature, prop is the name of the property that has changed
l = fp.getPropertyByName("Length")
w = fp.getPropertyByName("Width")
h = fp.getPropertyByName("Height")
self.scale.scaleFactor.setValue(float(l),float(w),float(h))
pass
def getDisplayModes(self,obj):
'''Return a list of display modes.'''
modes=[]
modes.append("Shaded")
modes.append("Wireframe")
return modes
def getDefaultDisplayMode(self):
'''Return the name of the default display mode. It must be defined in getDisplayModes.'''
return "Shaded"
def setDisplayMode(self,mode):
'''Map the display mode defined in attach with those defined in getDisplayModes.\
Since they have the same names nothing needs to be done. This method is optional'''
return mode
def onChanged(self, vp, prop):
'''Here we can do something when a single property got changed'''
if prop == "Color":
c = vp.getPropertyByName("Color")
self.color.rgb.setValue(c[0],c[1],c[2])
def getIcon(self):
'''Return the icon in XPM format which will appear in the tree view. This method is\
optional and if not defined a default icon is shown.'''
return """
/* XPM */
static const char * ViewProviderBox_xpm[] = {
"16 16 6 1",
" c None",
". c #141010",
"+ c #615BD2",
"@ c #C39D55",
"# c #000000",
"$ c #57C355",
def __getstate__(self):
'''When saving the document this object gets stored using Python's json module.\
Since we have some un-serializable parts here -- the Coin stuff -- we must define this method\
to return a tuple of all serializable objects or None.'''
return None
def __setstate__(self,state):
'''When restoring the serialized object from document we have the chance to set some internals here.\
Since no data were serialized nothing needs to be done here.'''
return None
def create():
obj=FreeCAD.ActiveDocument.addObject("App::FeaturePython","Box")
PointGroup(obj)
obj.Points = ((4275011518.128912, 507510589.4751387, 0.0),
(4275011717.0043764, 507511569.4996429, 0.0),
(4275011913.4291606, 507512550.0182727, 0.0),
(4275012107.4020367, 507513531.0248998, 0.0),
(4275012298.921793, 507514512.5133929, 0.0))
ViewProviderPointGroup(obj.ViewObject)
create()
- Joel_graff
If it works, go for it. Off hand, I don't see much in the code, except tha tyou might want to add code to destroy the node graph when the object is deleted...
I'm still working through the submodule issue. I've got most of it sorted out. Was going to try a FeaturePython implementation that uses pivy_trackers for SoGeo nodes as well - I'm gong to have to get rid of my use of lines in horizontal alignments.
Whatever you come up with will certainly be more lightweight, though.
- HakanSeven12
it works I didn't have any problem with object deleting. I don't think I need code for deleting.
- Joel_graff
One thing that needs to happen is creating a default separator / GeoOrigin when the workbench is activated, then removing it when it's deleted.
I think it's reasonable to assume most all work will require it, and there can't be more than one in a scenegraph, so I think it should be added as a singleton at the workbench initialization...
- HakanSeven12
What about creating a feature python object for it? We can save it to document.
- Joel_graff
I really don't see any value to wrapping the top level node structure in a FeaturePython object...HakanSeven12 wrote: ↑Thu Jun 04, 2020 4:06 pm What about creating a feature python object for it? We can save it to document.
I was thinking that when the workbench is initialized, we create an SoSeparator node with an SoGeoOrigin node under it, and make it a global singleton that's available everywhere. Then, you and I need only add SoGeo* nodes or other nodes as children of that SoSeparator if they rely on geo-referencing.
We could also create a singleton SoSeparator that is *not* geo-referenced (before the SoSeparator with the SoGeoOrigin), should we want to add nodes that are not affected by geo-referencing.
In any case, when the workbench/document is closed (or some other event requires destroying the data), we only need to remove the top separator node(s) to ensure all scenegraph changes are destroyed.
- HakanSeven12
I think that can cause problems when reopening saved document which contains SoGeo nodes. Because there won't be SoGeoOrigin but there will be other SoGeo nodes.
- Joel_graff
So long as the workbench is activated, it should be fine. But if it isn't, then it would be an issue...HakanSeven12 wrote: ↑Thu Jun 04, 2020 4:36 pm I think that can cause problems when reopening saved document which contains SoGeo nodes. Because there won't be SoGeoOrigin but there will be other SoGeo nodes.
