Awesome.HakanSeven12 wrote: ↑Sat Apr 27, 2019 12:49 pm Yes I think you can use red as default color of alignment
I will test it with my other alignments
Civil engineering feature implementation (Transportation Engineering)
- Joel_graff
Re: Civil engineering feature implementation (Transportation Engineering)
- HakanSeven12
When I create new project in your wb its change my unit to imperial.
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
Ah. Right. That's the default.HakanSeven12 wrote: ↑Sat Apr 27, 2019 1:06 pm When I create new project in your wb its change my unit to imperial.
You don't need to use that button. I haven't really decided if it's necessary. It just auto-creates groups and (obviously) sets the document units.
At this point, I'm thinking about removing it. I'm also open to other ideas, too. I really don't know if it's helpful to have a "new project" function.
- HakanSeven12
Okey. Another thing I cant change Seg Value. My curve segments are 80m. When I change the value nothing happen.Joel_graff wrote: ↑Sat Apr 27, 2019 1:09 pm Ah. Right. That's the default.
- Joel_graff
That's really odd. I've never had it fail. No errors in the Report View?HakanSeven12 wrote: ↑Sat Apr 27, 2019 1:14 pm Okey. Another thing I cant change Seg Value. My curve segments are 80m. When I change the value nothing happen.
Have you tried changing the segment method? I typically switch it to Interval and 10m or something... (I have to come up with better names for this stuff...)
- HakanSeven12
When I changed the method, aligment segments are chancing but still seg value broken.Joel_graff wrote: ↑Sat Apr 27, 2019 1:17 pm That's really odd. I've never had it fail. No errors in the Report View?
C:/Users/Hakan/Desktop/FreeCAD Data/Manisa.xml
utils.within_tolerance() - empty item list
- Joel_graff
Yeah, that doesn't mean anything. Actually, not sure why that's happening, but mostly it's a harmless diagnostic.
I've brought your XML file in and changed the Segment method and values and it works perfectly.
You could try adding print statements to the onChanged callback in freecad.trails/alignment/alignment.py - that would at least tell you if it's getting called.
Otherwise, unless I can reproduce the error (or you can spot an error message somehwere), I don't know what to say...
- Joel_graff
Can you get it to work in in any case? I mean, just import your XML alignment into a new document and try that.HakanSeven12 wrote: ↑Sat Apr 27, 2019 1:19 pm When I changed the method, aligment segments are chancing but still seg value broken.
- HakanSeven12
Its working odd. When I change the value and hit the enter its never work but if I change the value and click to drawing without enter its work.Joel_graff wrote: ↑Sat Apr 27, 2019 1:43 pm Can you get it to work in in any case? I mean, just import your XML alignment into a new document and try that.
- HakanSeven12
Some Seg Value inputs and segments length.
0.1------15.53
1.0------48.97
10-------153.59
0.1------15.53
1.0------48.97
10-------153.59
