Joel_graff wrote: ↑Thu May 02, 2019 3:39 pm
This has been fixed. Pull from dev.
First save ok
the second save is crashed
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails-dev\freecad\trails\project\project_observer.py", line 72, in slotStartSaveDocument
_cb()
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails-dev\freecad\trails\alignment\alignment_group.py", line 142, in write_xml
exporter.write(_list, template_path + template_file, xml_path)
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails-dev\freecad\trails\project\xml\alignment_exporter.py", line 186, in write
landxml.write_to_file(root, target_path)
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails-dev\freecad\trails\project\xml\landxml.py", line 115, in write_to_file
with open(target, 'w', encoding='UTF-8') as _file:
<class 'PermissionError'>: [Errno 13] Permission denied: 'C:\\Users\\Hakan\\AppData\\Local\\Temp\\FreeCAD_Doc_c0350148-5714-4c98-b554-97ab98c5a9e1_aa90b9_9040/alignment.xml'
