Civil engineering feature implementation (Transportation Engineering)
- Joel_graff
Re: Civil engineering feature implementation (Transportation Engineering)
Yeah, there's really no advantage to using lxml over xml.etree like I do. lxml has some performance advantages, but in the end, it's a third-party dependency that doesn't really make it worthwhile, I'm afraid. I did look into it a long time ago.
- HakanSeven12
I updated trails and it gives error
No module named 'freecad.trails.project.coin'
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\init_gui.py", line 220, in Initialize
from .project.commands \
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\project\commands\edit_alignment_cmd.py", line 33, in <module>
from ..tasks.alignment import edit_alignment_task
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\project\tasks\alignment\edit_alignment_task.py", line 50, in <module>
from ...trackers.alignment_tracker import AlignmentTracker
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\project\trackers\alignment_tracker.py", line 44, in <module>
from .curve_tracker import CurveTracker
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\project\trackers\curve_tracker.py", line 28, in <module>
from ..coin import coin_utils
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
I'll take a look at that today. I must have forgot to comment something out.
- Joel_graff
So things are really in flux atm. I've pushed some broken code. need to start using branches more often.
Anyway, I think I fixed it, but let me know.
- HakanSeven12
error
fix
new error
No module named 'pivy_trackers.tracker'
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\freecad\trails\project\trackers\curve_tracker.py", line 26, in <module>
from pivy_trackers.tracker.line_tracker import LineTracker
from pivy_trackers.pivy_trackers.tracker.line_tracker import LineTracker
from ...geometry import arc, spiral, support
from pivy_trackers.pivy_trackers.coin import coin_utils
from collections.abc import Iterable
#from ..support.tuple_math import TupleMath
from pivy_trackers.pivy_trackers.coin.coin_enums import NodeTypes as Nodes
from pivy_trackers.pivy_trackers.coin.todo import todo
from pivy_trackers.pivy_trackers.tracker.marker_tracker import MarkerTracker
from pivy_trackers.pivy_trackers.tracker.context_tracker import ContextTracker
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\pivy_trackers\pivy_trackers\tracker\line_tracker.py", line 28, in <module>
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\pivy_trackers\pivy_trackers\coin\coin_utils.py", line 30, in <module>
from .coin_enums import MarkerStyles
File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails\pivy_trackers\pivy_trackers\coin\coin_enums.py", line 28, in <module>
from ..support.const import Const
Yes. Some parts are missing I'm using "VS Code" for code editing and "Git (Submodule) Assistant" to get submodules.Joel_graff wrote: ↑Mon Jun 01, 2020 4:19 pm I'll take a look at that today. I must have forgot to comment something out.
- Joel_graff
Is your support folder populated?
When you git clone a project that has submodules, you have to individually clone the submodules. I didn't realize that till after I started using them. Starting to rethink doing that, but it makes stuff so much easier to handle.
This link explains that if you hadn't already figured it out.:
https://stackoverflow.com/questions/379 ... es#4438292
- HakanSeven12
You dont need to do it manuelly. You can use "Git (Submodule) Assistant" if you are using vs code. https://marketplace.visualstudio.com/it ... -assistantJoel_graff wrote: ↑Tue Jun 02, 2020 12:08 pm When you git clone a project that has submodules, you have to individually clone the submodules.
There is no "support" in your pivy tracker repository.
- support.png (117.48 KiB) Viewed 926 times
- Joel_graff
I see what I did. Sort of.
I've added support as a submodule in both trails and trackers. Then I added trackers as a submodule to trails. In other words, the same submodule is added twice, though in different locations.
Not sure why that would cause it to be removed, but I see the commit that removed it.
I'm going to try to sort this out and get back to you. it may take a while. If you can comment out stuff and get it running in the meantime, go for it.
And thanks for the submodule assistant tip.
- HakanSeven12
You are welcome
- Joel_graff
Ok, I removed and readded the submodule locally then pushed to remote.
Hopefully that will fix things.
