Civil engineering feature implementation (Transportation Engineering)
HakanSeven12
Re: Civil engineering feature implementation (Transportation Engineering)
Postby HakanSeven12 » Wed Jun 24, 2020 3:36 pm
thschrader wrote:
Wed Jun 24, 2020 3:19 pm
Works! :)
Good ;)
thotbuilds
Postby thotbuilds » Tue Oct 06, 2020 7:42 am
Hi All,
First of all thank you for the creators and contributes of this work bench. I am fairly new to free cad and have zero knowledge of python. I have been using linux on and off for about 9 years now though. All these things aside, I am trying to get OSM terrain details ( or any other terrain details like google or SRTM) of a specific co-ordinates for my architecture model. but trials work bench returns the below error. Using Freecad 0.19 appimage daily build. Could some one help me out tho get this thing working ?
13:06:25 Traceback (most recent call last):
13:06:25 File "/home/ekokynesis/.FreeCAD/Mod/freecad.trails/freecad/trails/GeoDataWB/import_heights.py", line 143, in runbl
13:06:25 import_heights(float(b),float(l),float(s))
13:06:25 File "/home/ekokynesis/.FreeCAD/Mod/freecad.trails/freecad/trails/GeoDataWB/import_heights.py", line 94, in import_heights
13:06:25 res=run(b,le,b,le +ld*0.001,size)
13:06:25 File "/home/ekokynesis/.FreeCAD/Mod/freecad.trails/freecad/trails/GeoDataWB/import_heights.py", line 49, in run
13:06:25 baseheight=getheight(tm.lat,tm.lon)
13:06:25 File "/home/ekokynesis/.FreeCAD/Mod/freecad.trails/freecad/trails/GeoDataWB/import_heights.py", line 34, in getheight
13:06:25 response = request.urlopen(source)
13:06:25 File "/tmp/.mount_FreeCAR6M2Kc/usr/lib/python3.8/urllib/request.py", line 222, in urlopen
13:06:25 return opener.open(url, data, timeout)
13:06:25 File "/tmp/.mount_FreeCAR6M2Kc/usr/lib/python3.8/urllib/request.py", line 531, in open
13:06:25 response = meth(req, response)
13:06:25 File "/tmp/.mount_FreeCAR6M2Kc/usr/lib/python3.8/urllib/request.py", line 640, in http_response
13:06:25 response = self.parent.error(
13:06:25 File "/tmp/.mount_FreeCAR6M2Kc/usr/lib/python3.8/urllib/request.py", line 569, in error
13:06:25 return self._call_chain(*args)
13:06:25 File "/tmp/.mount_FreeCAR6M2Kc/usr/lib/python3.8/urllib/request.py", line 502, in _call_chain
13:06:25 result = func(*args)
13:06:25 File "/tmp/.mount_FreeCAR6M2Kc/usr/lib/python3.8/urllib/request.py", line 649, in http_error_default
13:06:25 raise HTTPError(req.full_url, code, msg, hdrs, fp)
13:06:25 urllib.error.HTTPError: HTTP Error 504: Gateway Time-out
HakanSeven12
Postby HakanSeven12 » Tue Oct 06, 2020 12:15 pm
Import height not working but bernd working on it
bernd wrote:
Fri Sep 18, 2020 1:22 pm
@Joel_graff:
would you accept a PR which renames GeoDataWB to geoimport?
Do you have any progress on this?
baswein
Postby baswein » Tue Oct 06, 2020 10:11 pm
@thotbuilds
I too am really excited about this workbench but If you can't get it to work I have had fairly good luck with BlenderGIS the first 5mins of this video goes over it https://www.youtube.com/watch?v=Mj7Z1P2hUWk you should then be able to export it as an .obj and bring it into freecad. Of course you might end up with a lot of scaling and alignment issues. If you use .ifc files you could look into using blenderbim to export it from blender as an .ifc with geographic data. It might come in right then. The OSArch forum would probably be happy to help you figure that out. https://community.osarch.org/discussions
Joel_graff
Postby Joel_graff » Mon Oct 19, 2020 1:17 pm
Doing a little housekeeping on Trails. Geotechnical code has been moved to the 'geomatics' folder. @HakanSeven12 may want to test to ensure it's working properly.
Pull from the 'restructure' branch (not 'dev')
HakanSeven12 wrote: ping
y_skific
Postby y_skific » Mon Oct 19, 2020 5:16 pm
Hi Joel,
I'm also a civil enginer working in trackworks for 30 years now.
And just like you, i'm a bit disapointed by the leading Alignment softwares from Bentley or AutoDesk.
I just discovered FreeCAD, it's amazing capabilities, and the workbrench you are working on.
I went through a developement of an Alignment Editor a few years ago, you can see some swf demos just here: http://linea-trace.blogspot.com/
I still have the alignment object structure i wrote at that time and it was pretty stable, i re-worked on it last year to add a LandXML parser.
I was wondering if i could help i any way.
thschrader
Postby thschrader » Thu Oct 22, 2020 7:48 am
What must I do to mesh the points?
I updated trails-wb yesterday.
file (rename txt-extension to asc):
Bunny_asc.txt
(10.87 KiB) Downloaded 6 times
Error:
09:41:38  Traceback (most recent call last):
09:41:38    File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\surface\CreateSurface.py", line 183, in CreateSurface
09:41:38      nbase = utils.rendering_fix(base)
09:41:38  AttributeError: module 'freecad.trails.project.support.utils' has no attribute 'rendering_fix'
OS: Windows 10 (10.0)
Version: 0.19.22284 (Git)
Hash: bf1e8e48389f5e9e25bd77b67fe98da4213e797c
Python version: 3.6.8
Qt version: 5.12.1
Joel_graff
Postby Joel_graff » Sat Oct 24, 2020 2:22 pm
Hi Joel,
I'll take a closer look at what you developed. I've really only developed things just enough to work for my purposes, so I've no doubt there's a number of shortcomings. Always happy to have additional help, though I think this task might be a bit daunting for most folks to get involved. :)
All the same, whatever you feel like contributing,, I'm certainly open to it.
Joel_graff
Postby Joel_graff » Sat Oct 24, 2020 2:24 pm
I'll take a closer look. @HakanSeven isn't really able to spend time supporting it and I really don't know anything about the code he wrote, but I'll see if I can sort through the issue.
HakanSeven12
Postby HakanSeven12 » Sat Oct 24, 2020 8:49 pm
Joel is right. But I made a fix and I can't test. I hope it will works.
