Civil engineering feature implementation (Transportation Engineering)
Joel_graff
Re: Civil engineering feature implementation (Transportation Engineering)
Postby Joel_graff » Sat Nov 14, 2020 1:45 pm
pvandeneynde wrote:
Sat Nov 14, 2020 9:36 am
It works indeed as a alpha version.. congrats for the package and happy to dive into its possibilities!
Great!
HakanSeven12
Postby HakanSeven12 » Tue Nov 17, 2020 11:50 am
Hi Joel. I writed a GeoOrigin FPO. It can create a SoGeoOrigin node and edit its properties. You can get it by using this code.
from freecad.trails import geo_origin
origin = geo_origin.get(vector)
If there is an object funtion returns it. If not, function will create a new object. Vector is optional. If origin.Origin is (0,0,0) it use vector variable as origin. It has two properties.
zone = origin.UtmZone
geo_origin = origin.Origin
Also I added folders under it.
Joel_graff
Postby Joel_graff » Wed Nov 18, 2020 7:17 pm
Excellent!
I'm still working through some refactoring on my code, so I haven't had a chance to really look at this yet. I'll try to soon, but I just don't know when.
HakanSeven12
Postby HakanSeven12 » Mon Nov 23, 2020 10:03 am
I think I understand why there is a GeoSeparator node. If your coordinates has same system with your GeoOrigin you dont need it. But if your coordinates has not same system with GeoOrigin you can use GeoSeparator to define another system to scenegraph origin. That gives you to ability of use different coordinate system values in same scenegraph.
For example, you have two point file. First one is utm coordinates, second one is geodetic coordinates. You can create GeoOrigin with utm system for first file and you can use GeoSeparator with geodetic system for second file. Then you can convert your GeoOrigin origin coordinate to geodatic coordinates and use it as GeoSeparator origin coordinate.
That would be very helpful when using multiple coordinate systems in one scenegraph.
HakanSeven12
Postby HakanSeven12 » Sun Nov 29, 2020 8:41 pm
Hi Joel. The xml importer throwing some errors when I try to import any alignment. I can't send the report because I don't have a computer for now. Can you take a look when you have time?
balrobs
Postby balrobs » Sun Nov 29, 2020 9:23 pm
Maybe I can help. Tried to import @HakanSeven12 xml-file
"A Kolu Güzergah.xml"
and got probably the same errors
22:14:19  Missing Spiral Center coordinate in alignment K1 A Kolu
22:14:35  Traceback (most recent call last):
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad/trails/design/project/tasks/alignment/import_alignment_task.py", line 74, in accept
    result = alignment.create(_v, _v['meta']['ID'] + ' Horiz')
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad/trails/design/alignment/alignment.py", line 70, in create
    result.set_geometry(geometry, zero_reference)
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad/trails/design/alignment/alignment.py", line 365, in set_geometry
    self.model = alignment_model.AlignmentModel(geometry, zero_reference)
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad/trails/design/alignment/alignment_model.py", line 58, in __init__
    if not self.construct_geometry(geometry, zero_reference):
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad/trails/design/alignment/alignment_model.py", line 118, in construct_geometry
    self.validate_stationing()
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad/trails/design/alignment/alignment_model.py", line 523, in validate_stationing
    TupleMath.subtract(geo_coord, prev_coord))
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad_python_support/tuple_math.py", line 140, in subtract
    return TupleMath._operation(op_sub, op1, op2, fail_on_empty)
  File "/home/balrobs/.FreeCAD/Mod/Trails/freecad_python_support/tuple_math.py", line 114, in _operation
    return tuple(map(op, _op1, _op2))
<class 'TypeError'>: First arg must be Vector
System info:
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.23074 (Git) AppImage
Hash: 74b866ed3022fd1452c534dae31a721bcc668f2f
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Edit: removed the "A Kolu Güzergah.xml" attachement
HakanSeven12
Postby HakanSeven12 » Mon Nov 30, 2020 5:40 am
Thanks. Yes that is the error that I talked about.
bernd
Postby bernd » Mon Nov 30, 2020 8:32 am
Is it possible to install trails on windows without installing git?
HakanSeven12
Postby HakanSeven12 » Mon Nov 30, 2020 8:47 am
I didn't test with addon manager. I'm using visual studio code and git assistant to pull all files. But you can manually download repos an put them where they should be.
bernd
Postby bernd » Mon Nov 30, 2020 9:52 am
Either manually download nor AddOn manager will fetch the submodules.
