Civil engineering feature implementation (Transportation Engineering)
Joel_graff
Re: Civil engineering feature implementation (Transportation Engineering)
Postby Joel_graff » Mon Feb 18, 2019 6:28 pm
microelly2 wrote:
Mon Feb 18, 2019 5:48 pm
We can use the idea from here
Actually, the spiral curve as it's used in transportation engineering has a pretty well-defined model - no need to solve for it generally... Unless it's a more elegant solution? Anyway, a brief overview of the parameters and their mathematical definitions for a transportation engineering clothoid can be found here:
https://www.mathalino.com/reviewer/surv ... iral-curve
Given those parameters, I just need to sort out which ones need to be given by the user, and which can be calculated.
To this point, I know the distance between PI's, the simple curve radius, and the central angle of the simple curve. From that, I can probably get the spiral's tangent length (Ts), but to get the other parameters, I'll probably need to know one or more of the following: the spiral angle, the circular curve offset (length of throw), and the length of the spiral curve... That's just a guess, though.
If you can think of a better approach, though, I'd love to hear it. :)
You can find the FreeCAD Trails workbench for transportation engineering on my github at:
https://www.github.com/joelgraff/freecad.trails
Joel_graff
Postby Joel_graff » Tue Feb 19, 2019 12:01 am
HakanSeven12 wrote:
Mon Feb 18, 2019 2:55 pm
Spirals uses curve radius which its connected and spiral length input.
Ok, so in order to completely describe a spiral curve from beginning to end, I believe I need to know the following:
1. PI location - Either as a distance / bearing from previous PI or as an absolute northing / easting (x/y) coordinate
2. Circular/Central Arc size - Radius or degree of curve
3. Length of Spiral (as you indicated)
The first two parameters I require for simple/circular curves as it is. The third parameter should be all I need to build the spiral.
I'll play around with it - it might be a bit before I have something, though. Still, better to add this now than later, I think.
Joel_graff
Postby Joel_graff » Fri Feb 22, 2019 2:44 pm
HakanSeven12 wrote:
Mon Feb 18, 2019 10:14 am
Can we add clothoid object to curves?
Just an FYI, rudimentary support for spirals is in place. Right now, it's only for right-hand curves, because that's what I'm testing with :)
At present, it doesn't look quite right, and I'm having a hard time working up a test case. With a little more time, I hope I can iron out the issues or at least identify what limitations it has before moving on.
Need to keep pressing forward, so I can't promise a lot of polish on this at the moment, but I'll keep at it for another week or so to see what I can get done.
HakanSeven12
Postby HakanSeven12 » Fri Feb 22, 2019 2:59 pm
Good to see progress :)
Joel_graff
Postby Joel_graff » Sat Feb 23, 2019 9:40 pm
Thought now would be a good time to post an update video. This describes how horizontal alignments can be imported into FreeCAD. And yes, spirals work now. At least I think they do. :)
phpBB [video]
HakanSeven12
Postby HakanSeven12 » Sat Feb 23, 2019 10:53 pm
İt works :) I think we need something like horizontal alignment creation tool
Joel_graff
Postby Joel_graff » Sun Feb 24, 2019 12:54 am
I have an idea about that. I'm thinking we could use the Sketcher in a limited capacity. Essentially, if the user chooses a curve to edit, the curve (and it's adjoining tangents) could be created in a sketch and edited in it. Then, when the sketch is closed, the actual curve is rebuilt with the geometry as the user edited it in the sketch.
The Sketcher doesn't really handle long alignments or lots of geometry well, so using it to simply edit a single curve at a time, rather than maintain the entire alignment in one Sketch (which I was attempting to do previously) should work. That said, editing spirals / clothoids will prove quite tricky, I'm sure.
In any case, I don't think I really want to try to implement that now. I need to get vertical alignment importing implemented, then see what more I can do with 3D modelling.
Incidentally, the data I used to in the video is available in the Mod/transportationwb/data/alignment folder...
microelly2
Postby microelly2 » Fri Mar 01, 2019 2:01 pm
I made a script to create a pattern along a spline path with fixed length segments like a railway train with wagons. it may be an idea for special swept path problems. Still don't know whether is useful, but it was a fun to play with it.
the control points (double circles in the picture) belong to the curve and have the same distance to the others
see https://forum.freecadweb.org/viewtopic. ... 8&start=20
Joel_graff
Postby Joel_graff » Fri Mar 01, 2019 2:13 pm
My first thought would be applying symbology to lines - not line styles (like dashed lines), but symbols that overlay them.
Take a look at our highway standard for standard symbols, abbreviations, and patterns:
http://www.idot.illinois.gov/Assets/upl ... tterns.pdf
There are good examples of what I'm thinking about starting with the drainage items section and most of the sections that follow it. It's probably not the right way to do that, though...
The other potential use might be with the swept path analyzer...? Not so much for doing an analysis, but just as a possible visual aid.
Joel_graff
Postby Joel_graff » Mon Mar 04, 2019 10:45 pm
Just noting it here - this feature might come in handy for editing alignments without requiring the sketcher...
https://forum.freecadweb.org/viewtopic. ... 1&start=60
