Civil engineering feature implementation (Transportation Engineering)
Joel_graff
Re: Civil engineering feature implementation (Transportation Engineering)
Postby Joel_graff » Wed Jun 12, 2019 10:06 pm
If you fit to view, you'll see the main alignment zooms out because there's an arc farther up. I think that arc is part of the alignment with the curve issue I mentioned
You can find the FreeCAD Trails workbench for transportation engineering on my github at:
https://www.github.com/joelgraff/freecad.trails
HakanSeven12
Postby HakanSeven12 » Thu Jun 13, 2019 6:50 am
You are right. I check it in C3D. The problem is when you look at the alignment you will see a lots of little line and arc. They lenght near 2m. Because they are exploded spirals. In road plan there is only one spiral-arc-spiral element.
Also spiral object dont support this function. Icant create guide lines on spirals.
Coord, vec = Alignment.Proxy.model.get_orthogonal( Station, "Left")
Joel_graff
Postby Joel_graff » Thu Jun 13, 2019 12:15 pm
Right. I never zoomed in on it to see what was actually happening, lol.. Anyway, teh issue is broken geometry and I need to figure out how to deal with that so it doesn't just crash. That said, you might want to see if you can fix that bearing mismatch between the curve and the preceding line...
No it doesn't. No promises on when it will at this point.
Joel_graff
Postby Joel_graff » Thu Jun 13, 2019 12:36 pm
This issue is (somewhat) fixed. The invalid geometry is reduced to a zero-radius arc and it now renders the rest of the geometry in-place.
HakanSeven12
Postby HakanSeven12 » Thu Jun 13, 2019 12:47 pm
Its ok for me :)
Joel_graff
Postby Joel_graff » Thu Jun 13, 2019 1:00 pm
Its ok for me
Cool. Also, I just pushed preliminary support for ortho / tangent vector calculations for spirals. Give it a shot. I haven't tested it, so it's just a guess as to whether or not it works. Since you've got a functioning test case, I figured I'd test it on you. :)
HakanSeven12
Postby HakanSeven12 » Thu Jun 13, 2019 1:13 pm
Of course I can test it :)
  File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\Geomatics\Section\CreateGuideLines.py", line 158, in CreateGuideLines
  File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails-dev\freecad\trails\alignment\alignment_model.py", line 566, in get_orthogonal
    return _fn[curve['Type']].get_ortho_vector(curve, distance, side)
  File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails-dev\freecad\trails\geometry\spiral.py", line 438, in get_ortho_vector
    _coord = get_segments(_bearing, [_delta])[1]
  File "C:\Users\Hakan\AppData\Roaming\FreeCAD\Mod\freecad.trails-dev\freecad\trails\geometry\spiral.py", line 301, in get_segments
    _bearing = spiral['BearingIn']
TypeError: 'float' object is not subscriptable
Joel_graff
Postby Joel_graff » Thu Jun 13, 2019 2:08 pm
Try again. I manged to get it working on my end. Probably something else I've forgotten, though.
HakanSeven12
Postby HakanSeven12 » Thu Jun 13, 2019 2:39 pm
No error but looks weird
Joel_graff
Postby Joel_graff » Thu Jun 13, 2019 2:49 pm
Hmmm.. looks like the curve direction is reversed when the orthogonal is calculated.
In geometry/spiral.py, try changing line 433 from:
_vec.multiply(_x).normalize()
to:
_vec.multiply(-_x).normalize()
and give it another shot.
