Civil engineering feature implementation (Transportation Engineering)
HakanSeven12
Re: Civil engineering feature implementation (Transportation Engineering)
Postby HakanSeven12 » Mon Apr 06, 2020 7:11 pm
serviteur wrote:
Mon Apr 06, 2020 7:06 pm
Import point file (Trails) no work.
Send me your point file.
serviteur
Postby serviteur » Mon Apr 06, 2020 7:13 pm
ok.
elou.txt
(117 Bytes) Downloaded 6 times
HakanSeven12
Postby HakanSeven12 » Mon Apr 06, 2020 7:19 pm
ok.
Your file include semicolon but my importer support space, tab or comma and you need to change delimeter to your file type.
serviteur
Postby serviteur » Mon Apr 06, 2020 7:55 pm
ok.
I deleted all semicolon...and I have restored ImportPointFile.py >>>>>> .FreeCAD/Mod/trails-dev/freecad/trails/point/ImportPointFile.py and delete line 108
"UI.setWindowFlags(QtCore.Qt.Window)"
Point file import it's ok now but Create a surface no work
My point file Z=0 (Elevation)
Elou-Edit.txt
(109 Bytes) Downloaded 6 times
HakanSeven12
Postby HakanSeven12 » Mon Apr 06, 2020 8:08 pm
Distance between your point more than 20. Set max. Triangle length to 100 or higher. Also this thread for development discussions. İf you still have any problem write it to this thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=34371
serviteur
Postby serviteur » Mon Apr 06, 2020 8:29 pm
Ok.
thank you for your help.
HakanSeven12
Postby HakanSeven12 » Sat Apr 18, 2020 2:09 pm
Joel_graff wrote:
Fri Apr 03, 2020 9:13 pm
Hi Joel. I started to work on section views. But this code don't works for every alignment.
Alignment.Proxy.model.get_orthogonal( Station, "Left")
I fixed some part of your code at previous merge pr but still have some bugs. If you have time can you take a look at that?
Joel_graff
Postby Joel_graff » Sat Apr 18, 2020 9:01 pm
I’ll definitely take a peek in the next day or two. Thanks!
HakanSeven12
Postby HakanSeven12 » Fri Apr 24, 2020 10:53 am
I added a function to utils.py to fix rendering. If you use it for alignment placement, I think everythigs will works fine.
Joel_graff
Postby Joel_graff » Fri Apr 24, 2020 1:24 pm
Ok. I need to take a look at this. Been a bit distracted, lol. But I'm curious. :)
