pivy 0.6.2
Re: pivy 0.6.2
Hi @looo.
I am not involved in FreeCAD packaging/PPA effort anymore but following this procedure should get you there:
https://tribaal.io/very-simple-debian-package.html
Steps like creating a .deb package, signing it, uploading it to PPA ... are explained in a short and straightforward fashion.
Re: pivy 0.6.2
thanks for the information.
Also this approach doesn't give much success...
libsoqt-4 and libsimage is definitely available on my machine. No idea why these are "non sattisfied dependencies"...
lo@lo-desktop:~/projects/pivy/packaging/debian$ debuild
dpkg-buildpackage -rfakeroot -D -us -uc
dpkg-buildpackage: Information: Quellpaket pivy
dpkg-buildpackage: Information: Quellversion 6.2.0-0
dpkg-buildpackage: Information: Quelldistribution unstable
dpkg-buildpackage: Information: Quelle geändert durch Lorenz Lechner <sppedflyer@gmail.com>
dpkg-source --before-build debian
dpkg-buildpackage: Information: Host-Architektur amd64
dpkg-source: Information: Optionen aus debian/debian/source/options werden verwendet: --compression=bzip2 --compression-level=9 --single-debian-patch
dpkg-checkbuilddeps: Fehler: Nicht erfüllte Bauabhängigkeiten: libsoqt4-dev libsimage-dev
dpkg-buildpackage: Warnung: Bauabhängigkeiten/-konflikte nicht erfüllt; Abbruch
dpkg-buildpackage: Warnung: (Verwenden Sie -d, um sich darüber hinwegzusetzen.)
debuild: fatal error at line 1376:
dpkg-buildpackage -rfakeroot -D -us -uc failed
Re: pivy 0.6.2
And did you also install them?libsoqt-4 and libsimage is definitely available on my machine. No idea why these are "non sattisfied dependencies"...
Re: pivy 0.6.2
thanks, I thought it will pull the dependencies automatically...
Next problem...
Next problem...
cp: Aufruf von stat für 'NEWS' nicht möglich: Datei oder Verzeichnis nicht gefunden
dh_installdocs: cp --reflink=auto -a NEWS debian/python-pivy/usr/share/doc/python-pivy returned exit code 1
debian/rules:4: die Regel für Ziel „binary“ scheiterte
make: *** [binary] Fehler 2
dpkg-buildpackage: Fehler: Fehler-Exitstatus von fakeroot debian/rules binary war 2
Re: pivy 0.6.2
That's of course not possible because this would require the build script to run as root/sudo.thanks, I thought it will pull the dependencies automatically...
The file docs in the debian directory expects this list of filesNext problem...
NEWS
README
HACKING
THANKS
docs/ruby-inventor.txt
Re: pivy 0.6.2
These files should be in the zipped archive. Is the compression type a problem (tar.gz)? originally it was a bzip2...
Re: pivy 0.6.2
Re: pivy 0.6.2
I have this only locally. It is this file:
https://github.com/looooo/pivy/archive/v0.6.1-0.tar.gz
the structure looks like this:
├── debian
│ └── debian
│ ├── changelog
│ ├── compat
│ ├── control
│ ├── copyright
│ ├── debhelper-build-stamp
│ ├── docs
│ ├── pycompat
│ ├── python-pivy
│ │ └── usr
│ │ └── share
│ │ └── doc
│ │ └── python-pivy
│ ├── python-pivy.debhelper.log
│ ├── pyversions
│ ├── rules
│ ├── source
│ │ ├── format
│ │ └── options
│ └── watch
└── pivy_6.2.0.orig.tar.gz
Re: pivy 0.6.2
Note that in .dsc file under Build-Depends dependency python-support changed to dh-python in Ubuntu 16.04 and python-support isn't available anymore. As for:
It looks like you are using debuild command but you only extracted the debian folder. You need to extract the source too.
Re: pivy 0.6.2
The source or the compiled/installed files?triplus wrote:It looks like you are using debuild command but you only extracted the debian folder. You need to extract the source too.
Sorry for my dumb questions, but all I know about debian packaging is that is difficult...
