Bug report 0003020: 2D offset of circle are not in the right place
Gauthier
Postby Gauthier » Tue May 09, 2017 6:53 am
Recently, I found a curious behavior using the offset function to prepare a sketch for laser cutting (need offseting by the half of cutting width to have the exact dimention) :
URL : https://freecadweb.org/tracker/view.php?id=3020
When using the Part/2D offset of a circle, the resulting offset is moved to a XY parallel plane or/and translated from the original position of the origin circle.
The only solution to have the right offset from a circle is if the origine circle is in the XY plan and centered on the origine or the circle is inside a sketch and if the sketch is not moved in the XY plan.
- Start new model
- In the Draft workbench, draw a circle not centered on the origine or not on the XY plan then select the circle
- In the Part workbench, select 2D Offset
=> The offset geometry of the circle is moved on the XY plan if the circle is not on this plan
And the offset geometry is not centered on the circle.
Ex :
This strange behavior is the same on Linux or Windows :
FreeCAD version on Linux :
OS: Debian GNU/Linux 9.0 (stretch)
Version: 0.17.10967 (Git)
Hash: 38388cf650ef49cbce48af5dd33bdbe2487c8cbe
Python version: 2.7.13
OCC version: 6.8.0.oce-0.17
FreeCAD version on Windows :
Version: 0.17.10993 (Git)
Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291
Python version: 2.7.8
OCC version: 7.1.0
Re: Bug report 0003020: 2D offset of circle are not in the right place
Postby Kunda1 » Thu May 11, 2017 3:12 am
Can anyone test this on the latest 0.17 and confirm?
Postby Kunda1 » Sat Jun 03, 2017 3:30 pm
DeepSOIC wrote:ping
@DeepSOIC do you mind weighing in on this ticket? Thanks in advance!
DeepSOIC
Postby DeepSOIC » Sat Jun 03, 2017 5:04 pm
This isn't the first time I see strange behavior of Part 2D offset on circles, but this one is new. I can reproduce something similar in:
Version: 0.17.11018 (Git)
Hash: 0ad2e47f4d611a22f679e5b3ef5ed6851f8a02be
OCC version: 7.1.0
Postby NormandC » Sun Sep 17, 2017 5:00 pm
This is still happening in latest freecad-daily package (slightly behind current master), and not only with Draft Circles, but with a Part primitive circle or a Sketch containing a circle.
And if you change the position of the circle in X/Y/Z, the resulting 2D Offset can flip up or down... Very weird!
OS: Ubuntu 16.04.3 LTS
Version: 0.17.12124 (Git)
Build type: None
Hash: 76e8d81ae24ab898396571898525f78e1efbbcba
Python version: 2.7.12
OCC version: 7.1.0
Locale: French/Canada (fr_CA)
FC017_Circle_2D_Offset_bug.fcstd
(15.51 KiB) Downloaded 11 times
Chris_G
Postby Chris_G » Mon Jan 01, 2018 11:38 am
I had a look on this bug.
I don't know if it is of any help, but the Offset2D of circles seems to need an inversed Placement of its source circle.
The attached file contains primitives with random placements, and Offset2D applied on them later.
All is good, except for the circle Offset.
It gets fixed by typing :
obj = App.getDocument("Offset2DBug").getObject("Offset2D004")
obj.Placement = obj.Source.Placement.inverse()
Ping
Maybe this can help narrow down the origin of this bug ?
Offset2DBug.fcstd
(9.21 KiB) Downloaded 11 times
freecad-heini-1
Postby freecad-heini-1 » Mon Jan 01, 2018 1:43 pm
I remember a similar problem to create a parting plane along a silhoutte for plastic injection mold inserts.
Shape2DView from the Draft workbench are not working as expected. Why?
Here you can see what I mean with video:
https://forum.freecadweb.org/viewtopic. ... 00#p193700
Postby wmayer » Sat Jan 26, 2019 9:56 pm
