Part.Wire misses some Edges
bernd
Re: Part.Wire misses some Edges
Postby bernd » Wed May 24, 2017 8:27 pm
It works without BooleanFragments too. Just only add the missing Edges to the Part.Wire works ...
Load nonmanifold_wire.fcstd from first topic post
edges = App.ActiveDocument.Compound.Shape.Edges
w = Part.Wire(edges)
for ed in edges:
    missing_edge = True
    for ew in w.Edges:
        if ed.CenterOfMass == ew.CenterOfMass:
            missing_edge = False
            break
    if missing_edge:
        w.add(ed)
Part.show(w)
@DeepSOIC:
Why is it possible to add all Edges to the BooleanFragments and the BooleanFragments behaves like a magician and deletes the doubeled ones?
bernd
DeepSOIC
Postby DeepSOIC » Thu May 25, 2017 3:00 pm
bernd wrote:Why is it possible to add all Edges to the BooleanFragments and the BooleanFragments behaves like a magician and deletes the doubeled ones?
I don't quite understand shat you are asking. I'll try to explain why did I do what I suggested.
In OCC, the connectivity of things is usually defined by sharing. For example, a compsolid. Compsolid is merely a list of solids, and the connectivity is defined by face sharing.Same with shells, and wires. I'm not sure if that's the only information about wire connectivity, but vertex sharing is at least required.
Part.Wire(edges) assembles wires. If the edges have coincident but not shared vertices, the vertices are made shared. As consequence, new edges are created. However if you feed edges where vertexes are pre-shared, Part.Wire will use the very edges you supply, and you can then test if the edge is in wire by looping through wire edges and comparing with isSame() method.
That's what booleanfragments was for. I used it as a way to establish vertex sharing, before building the wire.
I think the final bit of the puzzle is suggested by microelly2. That is why we have to add edges twice. I think, OCC adds edges one by one, and will silently reject an edge if it doesn't connect to the rest of the wire. Adding all edges the second time is a hacky workaround, which assumes that most of the wire was built by the very first call, and that adding an edge that already is in the wire will be ignored.
bernd
Postby bernd » Sat May 27, 2017 9:20 am
thanks for the explanation.
If all edges are added twice to a Part.Wire lots of edges are added twice and it results an an invalid shape. If all edges are added to to a BooleanFragment of a Part.Wire all edges which are already in the wire are ignored and it results in a valid shape. I would like to know why are they ignored in the BooleanFragment?
bernd
bernd
Postby bernd » Sat May 27, 2017 5:03 pm
:shock: :o :mrgreen: :D
it is much more simpler ... Just pass the BooleanFragment of Edges to GMSH and it will connect the Edges. These BooleanFragments are magical ... This would mean in the brep passed to GMSH there is written that it is not a Compound but a BooleanFragment containing a Compound. But Part --> Check Geometry does not show any difference ?!?
Mhh I really do need to know more detailed what really these BooleanFragments are ... Is there some resources ?
I tested with faces and BooleanFragments too, same magical. Pass a BooleanFragment of faces to GMSH and the Mesh of faces (which would form a nonmanifold shell) is connected.
booleanfragments_edges.fcstd
(75.3 KiB) Downloaded 7 times
booleanfragments_shell.fcstd
(247.57 KiB) Downloaded 6 times
tanderson69
Postby tanderson69 » Sat May 27, 2017 7:46 pm
bernd wrote:
Sun May 21, 2017 7:18 pm
tanderson69 wrote:Curious, what does gmsh do with a compound of 'connected' edges?
Same what GMSH meshes if you pass a Compound of "connected" Solids instead of one CompSolid or if you pass a Compound of "connected" Faces instead of one Shell or a Compound of "connected" Edges instead of one Wire. GMSH will mesh them in one big mesh but will not connect them means for the connected Edges in the mesh there will be at a vertex where 3 Edges meat there will be three nodes. Each Edge will have his own node, thus the Edges are not connected. If you pass one wire GMSH will make one Vertex at the point where the three edges are connected. GMSH just meshes what it gets. Means you need to pass the wire as brep.
bernd
so do you still think this?
bernd
Postby bernd » Sat May 27, 2017 9:55 pm
bernd
Yes ! if it is passed as a Compound (a bound of connected not glued edges) they are not Connected (glued) in the mesh. If it is passed as a BooleanFragment Compound (a bound of connected not glued (I don't know may be there are glued already in a BooleanFragment but that is what I have to learn)) they are connected (glued) in the mesh ! Example will follow ...
tanderson69
Postby tanderson69 » Sat May 27, 2017 10:11 pm
Does this mean you didn't need to run the booleanFragment edges through 'Part.Wire'?
bernd
Postby bernd » Sat May 27, 2017 10:15 pm
Exactly ! Thats the magical thing and it works on nonmanifold shells too. Just pass a bound of faces as a BooleanFragmentsCompound to gmsh and the faces in the mesh will be glued !
bernd
Postby bernd » Sat May 27, 2017 10:16 pm
as promised the example
BooleanFragments compound mesh has 5 nodes
Compound mesh has 6 nodes
>>> App.ActiveDocument.BooleanFragments001_Mesh.FemMesh.Nodes
{1L: Vector (0.0, 0.0, 0.0), 2L: Vector (100.0, 0.0, 0.0), 3L: Vector (200.0, 0.0, 0.0), 4L: Vector (50.0, 0.0, 0.0), 5L: Vector (150.0, 0.0, 0.0)}
>>> App.ActiveDocument.Compound_Mesh.FemMesh.Nodes
{1L: Vector (0.0, -100.0, 0.0), 2L: Vector (100.0, -100.0, 0.0), 3L: Vector (100.0, -100.0, 0.0), 4L: Vector (200.0, -100.0, 0.0), 5L: Vector (50.0, -100.0, 0.0), 6L: Vector (150.0, -100.0, 0.0)}
node 2L and 3L are at the same place, one belongs to the first edge and the other to the other edge. The edges are not glued together in the mesh.
or select the mesh right mouse button mesh info
compound_vs_booleanfragmentcompound.fcstd
(9.26 KiB) Downloaded 6 times
EDIT: the forum code tags have line ending problems I deleted them for now
tanderson69
Postby tanderson69 » Sat May 27, 2017 10:32 pm
That is what I thought, and that is what my first question was about. Thanks.
