Part.Wire misses some Edges
bernd
Re: Part.Wire misses some Edges
Postby bernd » Sat May 27, 2017 10:52 pm
tanderson69 wrote:
Sat May 27, 2017 10:32 pm
bernd wrote:
Sat May 27, 2017 10:15 pm
Exactly ! Thats the magical thing and it works on nonmanifold shells too. Just pass a bound of faces as a BooleanFragmentsCompound to gmsh and the faces in the mesh will be glued !
That is what I thought, and that is what my first question was about. Thanks.
Do you know why does the BooleanFragmentsCompound glues the Elements together in the OCCT mesher GMSH, or do you know some resources about this. I assume the reason for this is in OCCTs BooleanFragmentsCompound.
I have been testing the next step in all this gluing stuff. Mixed glued meshes of Volumes and Faces (interesting for some guys around in FEM) or Faces and Beams (interesting for me in the regard of building structure analysis) by the use of BooleanFragmentsCompounds. But I would not like to bring in to much at once ... But again it is all about these BooleanFragments ...
tanderson69
Postby tanderson69 » Sun May 28, 2017 2:21 am
Just because 2 vertices, on 2 different edges, share the same position in 3d space doesn't mean the edges are 'connected'. The 2 edges need to share the actual vertex.
I extracted 2 adjacent edges from the default cube. Then added the edges to a compound and ran the compound through check geometry.
Then took extracted edges and ran them through a fusion and ran the fusion through check geometry.
notice the vertex numbers. That is it.
bernd
Postby bernd » Sun May 28, 2017 9:35 am
ahh sure the cound of vertices, edges and faces shows if shapes share vertices and thus are glued to each other. It is what I assumed. GMSH meshes what it gets. Means the topology is glued together already. Glued and connect are not that good words. You described it much better, they share topology. If Shapes share vertices in geometry they gone share these vertices in the mesh and the mesh is glued, no magical. Back to the magical BooleanFragments. For some reason no matter what is passed to a BooleanFragment the Elements share Vertices and Edges. Thats wonderful for FEM topology. Attached two more simple example:
your two edges run to a BooleanFragment --> 3 Vertices --> the edges share a Vertex
three faces run through BooleanFragment --> two Vertices and only 4 Edges --> the three faces share one edge --> YEAH
EDIT:
It seams BooleanFragments does make shared Vertices, Edges and Faces by default. Still I'd be interested in some more resources in this regard.
bernd
Postby bernd » Sun May 28, 2017 9:49 am
a more sophisticated example. 3 faces and 3 edges, run through a BooleanFragment. YEAH they share the Vertices and the Edges ...
The Boolean Fragment only has 2 vertices and 7 Edges (6 Circles and the one they all share) :D
edges-faces-shared-topology.fcstd
(13.7 KiB) Downloaded 23 times
bernd
Postby bernd » Sun May 28, 2017 10:00 am
Just to proof this for the faces too.
attached two cubes run through a Boolean Fragment. They have shared faces, edges and vertices. That is why they are glued in meshing even if no CompSolid is made out of the BooleanFragment. This all means the magical for FEM are not the CompSolids, the magical is the BooleanFragment !
two solids, 12 vertices (4 shared), 20 Edges (4 shared), 11faces (one shared)
:D
bernd
Postby bernd » Sun May 28, 2017 10:27 am
another example ... The BooleanFragments does not only the sharing, it does create new edges and faces if they are needed to make the shared topology. Attached an example of 3 faces run through a BooleanFragment
If the base face is extracted from the BooleanFragment one can see it has the edges. Very important to make a valid FEM mesh out of the BooleanFragment. :D
tanderson69
Postby tanderson69 » Sun May 28, 2017 1:29 pm
Not sure what you want, but it looks like the relevant code that deepsoic wrote is in src/Mod/Part/BOPTools
bernd
Postby bernd » Sun May 28, 2017 1:46 pm
BooleanFragments are not some FreeCAD thing they are originated in OCCT. Means like for a fuse for a BooleanFragment everything seams passed to OCCT and OCCT returns the result. Means the answer seams to be find in OCCT not in FreeCAD. Ahh here is where the magic starts ...
https://github.com/FreeCAD/FreeCAD/blob ... res.py#L86
bernd
Postby bernd » Sun May 28, 2017 1:51 pm
@tanderson69: again you are better than me ...
What we are talking about seam called generalFuse ...
https://github.com/FreeCAD/FreeCAD/blob ... py#L46-L48
and here it goes to OCCT
https://github.com/FreeCAD/FreeCAD/blob ... 1644-L1655
tanderson69
Postby tanderson69 » Sun May 28, 2017 1:51 pm
https://dev.opencascade.org/doc/overvie ... gorithms_7
