Curves workbench
triplus
Re: Curves workbench
Postby triplus » Fri Jan 25, 2019 9:58 pm
Chris_G wrote:
Fri Jan 25, 2019 9:05 pm
I agree. That would be my preferred workflow.
In example @looo made that seem possible. Maybe over time you two can figure out if something is still missing in Pivy, to make that more streamlined. I guess now it should be a bit easier. As there is an additional developer leveraging such capabilities. ;)
Sorry for that. I am currently in a delicate situation where I can't compile FC anymore. So I use a PY3/Qt5 Appimage, but I cannot test other builds. Would you have a console log of the crash please ?
There is Py2/Qt4 AppImage available too, said that, it doesn't crash. This therefore feels like some glitch on my system and as such i don't feel it makes much more sense to look into it further. I have a newer, compared to the default, Pivy installed and likely there is an issue involved related to that. And in the end i am not sure on how Python 2 compatible the latest Pivy currently is or intends to be in the future.
Chris_G
Postby Chris_G » Fri Feb 01, 2019 5:57 pm
The editable interpolation curve tool should now work also with pivy 0.6.4
I think it works quite well to model hulls, wings, etc ...
Boat-2.fcstd
(33.53 KiB) Downloaded 70 times
Postby chrisb » Fri Feb 01, 2019 7:18 pm
This looks great. I'm looking forward to modeling the mud wings of a prewar car ...
hammax
Postby hammax » Sat Feb 02, 2019 8:02 am
… sorry, still there are no editable profiles
Win10_32
FC0.18.15748
CurvesWB (update 15h old)
Chris_G
Postby Chris_G » Sat Feb 02, 2019 8:29 am
Argggh ... any message in the report view ?
Could you please try these lines in the python console :
import graphics
from graphics import COLORS
import pivy
pivy.__version__
hammax
Postby hammax » Sat Feb 02, 2019 12:31 pm
Hi Chris,
that is what I get after invoking your code => some utils missing?
Old python. Why doesn't it update when downloading actual 18-pre versions?
Python 2.7.14 (default, Feb 28 2018, 16:59:39) [MSC v.1800 32 bit (Intel)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> import graphics
  File "C:\Users\Max\AppData\Roaming\FreeCAD\Mod\Curves\graphics.py", line 2, in <module>
    from pivy.utils import getPointOnScreen
ImportError: No module named utils
>>> import pivy
>>> pivy.__version__
Chris_G
Postby Chris_G » Sun Feb 03, 2019 12:54 pm
Hi Chris,
Thanks.
Your pivy version is too old, unfortunately.
I think the standard builds are still py2/qt4.
The Conda builds are py3/qt5, but they are only for x64 (you are using 32 bits FreeCAD).
Gift
Postby Gift » Fri Feb 15, 2019 5:24 pm
Is this known?
Chris_G
Postby Chris_G » Sat Feb 16, 2019 9:43 am
Yes. GeomInfo tool give information about the underlying geometry of an edge or face.
Here, you get information about the full circle that supports your edge.
soaring
Postby soaring » Mon Feb 25, 2019 1:35 pm
Hello, i'm trying to use the interpolation curve tool.
i understand keyword shortcuts need, but it's not clear for me how to use the tool with external shape. Is someone can do a youtube video to see the toll in action ?
My "learning curve" could be better :-) thanks !
